Need advice on Performer X manifold + 68mm throttle body
Old Oct 26, 2007 | 04:12 PM
Teamdiesel's Avatar
Default Need advice on Performer X manifold + 68mm throttle body
I just got my PerformerX manifold for my B18C5 build, went to the machine shop to bore the opening to 68mm only to find out he can't do it. He said that he doesn't have anything big enough to clamp the manifold in place to mill it. He used his digital inside-outside caliper and measured 65.98mm diameter on th emanifold, so I decided to bolt it to the throttle body and see what is the difference like. I need you guys to look at it and tell me if there would be any drawbacks in bolting them together "As Is".
Old Oct 26, 2007 | 04:24 PM
Chris Tune's Avatar
Default Re: Need advice on Performer X manifold + 68mm throttle body (Teamdiesel)
even with a dremel and some patience it can be done... if you know what you are doing.
Old Oct 26, 2007 | 04:28 PM
A.E Motoring's Avatar
Default Re: Need advice on Performer X manifold + 68mm throttle body (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">even with a dremel and some patience it can be done... if you know what you are doing.</TD></TR></TABLE>
Old Oct 26, 2007 | 04:29 PM
Teamdiesel's Avatar
if I was to use a dremel, it would be best to do it with the TB still bolted,right?
Old Oct 26, 2007 | 04:30 PM
Default Re: (Teamdiesel)
yea u can do that, or just mark it where it needs to be cut
Old Oct 26, 2007 | 04:41 PM
grjp1988's Avatar
I just ordered my performer x and was going to buy the 70mm tb with it. but for the 70mm tb to be effective i will have to bore the manifold out to match the tb?
Old Oct 26, 2007 | 04:42 PM
Default Re: (grjp1988)
well it will be better to have it matched, so it will just all flow together
Old Oct 26, 2007 | 04:56 PM
dinko's Avatar
Default Re: (Dual Cam Racing)
bolt it on...use something to mark the edge that's "sticking out", take the tb off, get the dremel and go to work
if you port it a little bigger than what you marked, i believe this is okay but i would just be careful and take my time so the air has a nice transition from TB &gt; IM (aka port matching)
Old Oct 26, 2007 | 05:20 PM
grjp1988's Avatar
will the stock itr tb bore to 70mm cause im not going to buy a 70mm tb if i can just bore mine out for cheaper.
aka.. bolt itr tb to px manifold bore both to 70mm... will it work?
Old Oct 26, 2007 | 05:41 PM
Natural Aspirations's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">will the stock itr tb bore to 70mm</TD></TR></TABLE>
No and you do not need a 70mm throttle body....
Old Oct 26, 2007 | 07:00 PM
Project_EK's Avatar
Get the throttle body gasket, put it up 2 the manifold n mark the opening..get a dremel n go 2 town...
MADBADGER
Honda S2000
17
Mar 27, 2008 12:34 PM
B18c1-Integra
13
Feb 22, 2008 05:34 PM
92 CIVIC HATCH VX
Jun 12, 2007 11:06 AM
JDM00SI
Nov 14, 2005 08:59 AM
Turbo R
33
Apr 15, 2005 11:28 PM
