V2V
Would life be lift? I am just guessing here, but when either IN or EX cam are at max. life(lift) the other is closed. Figure out the 4 strokes and cam numbers for timing, it allways pays when you figure it out for yourself. Here is question 2 , does max. cam lift have anything to do with valve to piston clearance?
Hi there do you know what not set it as 0.007" on IN and 0.008" EX valve lash to check the valve cleanance? why they put it on 0.00 valve lash. Why is that? I don't understand.
Because when the engine gets to temp that lash zero's out. Besides, the closer you set it the more leave-way you have. If you don't have the engine already assembled, don't use a head gasket when checking P2V clearance.
Hi thanks for your info, and why not fit head gasket when checking it? Is it because when it's hot the piston will close to the head? Or for something else?
Thanks a lot very helpful.
You are actually just checking V-V at .0000 lash. The ACTUAL reason is that is where the cam specs are set at. Duration @ .o50 is set at .0000 clearance. Plus with a GED and you find V-P clearance at .000 valve adj. is .050 you would add .007 x 1.55 and figure you are @ .0655. Just math.
getgot22
12
Mar 6, 2007 06:36 PM
redintegra
Oct 7, 2002 09:17 AM
