Itb's post!
Itb's post!
post your set up if u are running itbs..
whats your numbers?
what did it run?
i just picked up some home made itbs and this is the set up its going on.
block.
darton sleeve integra block. b18b1.
brand new OEM 85.mm head gasket
wiseco 13.1 pistons.
eagle rods
arp rod bolts
arp head studs.
brand new OEM type r water pump
brean new oem itr timing belt
Balanced crank
ACL Race bearings
ACL Main bearing
JG header.
Head
dtr big port.
3 angle valve job
supertech valve guides
supertech flat valve's
supertech Springs
buddyclub stage 3 cams
buddyclub cam gears
benen fuel rail
rc 440 injectors.
whats your numbers?
what did it run?
block.
eagle rods
arp rod bolts
arp head studs.
Balanced crank
ACL Race bearings
ACL Main bearing
JG header.
Head
dtr big port.
3 angle valve job
supertech Springs
buddyclub cam gears
benen fuel rail
rc 440 injectors.
Re: Itb's post! (Your Name)
twm 50's, 12:1 ls/vtec, pro1's, stock port, an-r header, 2.5 inch exhaust.
my motor (solid lines) vs. k20 street tuned w/ intake/rbc/swap header (dotted)
made 196/140 if you cant read it.
50mm ITB's
No numbers yet.
No E.T. yet.
Just a JDM SOHC 1.6 ZC
I have a ported head, Bisi cam and AEM EMS ready to go in it, this summer has just been too busy.
No numbers yet.
No E.T. yet.
Re: Itb's post! (junkyard racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junkyard racer »</TD></TR><TR><TD CLASS="quote">OBX ITB's. Never fired them up. **** happened and I wasn't able to finish the project.
my favorite pic
</TD></TR></TABLE> your not in japan anymore
my favorite pic
ITB
So, forgive my ignorance on these, but what is the advantages of running ITB's?
I realize more air flow. But I am thinking about installing a set on a 95' LS Integra. What am I getting myself into?
Re: ITB (jwrape)
look how flat my tourque curve is, and how smooth my hp curve is, that is part of the role if the itb's.
they can be a pain to install both mechanically and money wise tho.
Re: Itb's post! (killerpenguin21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 »</TD></TR><TR><TD CLASS="quote">twm 50's, 12:1 ls/vtec, pro1's, stock port, an-r header, 2.5 inch exhaust.
nice set up
nice set up
Re: (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR »</TD></TR><TR><TD CLASS="quote">90x102 H motor
15:1
Portflow Headwork
Crower cams
Ericks Header
52mm TWM Itbs portmatched to head
318hp / 228 tq
Holy ****! Do you have any track #'s of this setup? This should be a 10sec all motor car! Goodluck on this build
15:1
Portflow Headwork
Crower cams
Ericks Header
318hp / 228 tq
King of the One Liners
Re: (2.0 and up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0 and up »</TD></TR><TR><TD CLASS="quote">
Holy ****! Do you have any track #'s of this setup? This should be a 10sec all motor car! Goodluck on this build</TD></TR></TABLE>
It SHOULD have been yes. . . Transmission/clutch problems first time at track and then second time my pistons decided it was hungry and it ate a valve for a snack . . .
Re: (illfaded)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illfaded »</TD></TR><TR><TD CLASS="quote">dont buy cheap itb's. spend the money and do it right. oh yeah build the motor first</TD></TR></TABLE>
the next time I install these, they are going on an OEM bottom end and I am very confident in the OBX ITB's.
Re: (2fastGSR)
It SHOULD have been yes. . . Transmission/clutch problems first time at track and then second time my pistons decided it was hungry and it ate a valve for a snack . . .</TD></TR></TABLE>
too much POWA!!!!!!!!
Re: (2fastGSR)
15:1
Portflow Headwork
Crower cams
Ericks Header
318hp / 228 tq
Portflow Headwork
Crower cams
Ericks Header
318hp / 228 tq
Re: (jdmda7)
15:1
Portflow Headwork
Crower cams
Ericks Header
318hp / 228 tq
Clean. So this setup doesn't exist anymore? I always thought h2b cars would have issues with the horns of the itb's clearing the MC
15:1
Portflow Headwork
Crower cams
Ericks Header
318hp / 228 tq
