Need some help on golden eagle head studs torque specs
not sure if this is the right place,I got a b18b going to put a b16 head on it I need to know the torque spec
please that's the only thing stopping me from finishing my build I know that b20/b18c
are the same please someone help
Re: Need some help on golden eagle head studs torque specs (HondaCamp)
i just got finished installing GE headstuds a few hours ago.
the instructions say to torque the studs into the block to 10ft/lbs.
then with the supplied lube on the threads/washers/nuts you torque them down to:
25ft/lbs first pass
50ft/lbs second pass
then the instructions tell you to loosen and retorque each nut back 50ft/lbs 3 times to properly stretch/seat the threads. do one nut at a time. do not loosen them all at the same time.
then the final torque spec is 72ft/lbs
hope that helps.
25ft/lbs first pass
hope that helps.
Re: Need some help on golden eagle head studs torque specs (non-VTEC)
thanks<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">i just got finished installing GE headstuds a few hours ago.
25ft/lbs first pass
hope that helps.
</TD></TR></TABLE> thanks man u made my day bro
25ft/lbs first pass
hope that helps.
HondaCamp
08-19-2008 04:46 PM
BrightRedOne
10-24-2004 09:45 AM
