b16b stroke
b16b stroke
I have a b16b im planning to stroke, my plan is to retain the b16b block put an gsr crank and rods and use the pct piston. My question would be it will be a direct fit using the gsr crank and rods to my b16b block?
Re: (d15Beta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15Beta »</TD></TR><TR><TD CLASS="quote">it should be.. hehe btw wana sell ur 16b crank? hehe</TD></TR></TABLE>
i have one, pm me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">it would be a 1.8l ctr motor, making it a ITR engine basically</TD></TR></TABLE>
pretty much , just with higher compression. and yes OP it all bolts up.
i have one, pm me.
Re: (d15Beta)
Your not really stroking the motor seeing how the B16B is a de-stroked B18C Type R block. Your just making it a 1.8
The deck height is the same as the B18C.
Re: (Flint707)
Re: (blinx9900)
Spoon stroker kit. It's affordable for a spoon product and its comprehensve.
You might be able to find it cheaper elsewhere but... http://inlinefour.com/spoon18lstro.html
Re: b16b stroke (Wytek9)
It will fit... No issues, but i was you i would definitely swap my rod bolts for ARP rod bolts for security.... I have a similar build on the way... Im planning on putting in a balanced, with oil holes chamfered B18A cranshaft and Eagle LS rods...... I have it in my possesion but there are just a few odds and end am waiting on to complete the transformation....
Re: b16b stroke (EK9 CTR)
oh i just saw you wanted to use the PCT pistons...dont. Your piston to deck height will be too close and your compression will be well into the 12's.
In all honesty I dont think there's a more complete purchase than the Spoon stroker kit. The only thing it doesn't come with is the bearings, which you would have to set clearances with anyways.
SilverEk3dr
02-17-2006 09:42 PM
