PTW clearances p29's
Old 01-27-2009, 01:21 PM
sparkyd16itb's Avatar
Default PTW clearances p29's
Right i am in the process of building my d16z6 the sepc for the bottom end goes
YCP P29'S 76MM
SHOTPEENED RODS
ARP ROD BOLTS
ACL MAIN/ROD BEARINGS
Am i right in thinking that because ycp's are oem replacment (even if they will take more abuse) when rebore the block i use the service manual PTW clearances and ring gap clearances regardless of bore size?
Might sound a bit stupid but i want it spot on im also going to be running a 40bhp shot of nitrous should i increase the gaps at all?
Old 01-27-2009, 03:16 PM
racebum's Avatar
Default Re: PTW clearances p29's
YCP P29'S 76MM
SHOTPEENED RODS
ARP ROD BOLTS
nearly every cast piston i have seen that runs around 3.2" uses a .0015 PWC
it's only forged pistons that need to be setup larger.
Old 01-27-2009, 03:21 PM
88Hatchy's Avatar
.0015 sounds correct
If you are planning to use nitrous with cast pistons, you might want to consider having the the piston tops coated.
Old 01-27-2009, 03:47 PM
DonF's Avatar
So would 76mm be tighter than 3.2 inches?
Old 01-27-2009, 04:12 PM
88Hatchy's Avatar
Would the .2" difference actually make a significant difference in how much the piston would expand? I'm just curious if it would put it too close to the factory service limit.
Old 01-28-2009, 09:53 AM
t
Old 01-28-2009, 09:55 AM
Thats cool then. It was just the guy doing my machine work wanted me to go and check first he said the same as everbody eles but wanted to be sure as he has never used or seen ycp pistons.Thanks guys much appreciated
Old 01-28-2009, 10:12 AM
racebum's Avatar
what do you usually set those little 3" guys up at don? don't these cast pistons have a range from .001 to .002 you can play around with depending on size, use, and application?
also, if you have a minute i'd love to pick your brain on why my last motor failed & get a few ideas on how to prevent it in the future.
kenny6
06-09-2014 05:48 AM
dart2.2
12-20-2009 11:08 AM
kreatekustomz
07-06-2009 07:24 AM
one slow coupe
10
02-06-2007 01:57 PM
Quick Reply: PTW clearances p29's
