blox type C too big for stock itr?
Old 04-19-2009, 11:00 PM
hai_tech's Avatar
Default blox type C too big for stock itr?
i juss dyno my car yesterday mak 141 HP wat could be wrong!!! i was told the blox C cams to big for my setup, they try adjust the cam gear n degreeing but mak no power, bought this cams fr project dc2 i ask him which one you recomend better he told me get the type c, like i say everyone told me the cams, wat u guy think?
setup stock b18c5 top to end
mod -blox c cams , supertech valve spring n reatainer,skunk2 cam gear, rc440cc,higheend header, full catback wit test pipe,intake wit stack,walbro 255, tune s100 in p28
Old 04-19-2009, 11:49 PM
redGSRguy's Avatar
Default Re: blox type C too big for stock itr?
I did 200/130 with the type C's on my b18c1. Tuned on hondata s200. What did the car make before the cams? With i/h/e and mild cams my b18c5 put down 185/123.
Comptech Icebox / OEM JDM 4-1 / RS*R exhaust
Portflow head / Supertech Valves / Rocket spring + retainers / OEM JDM o/s itr pistons / Blox IM / Lucas 370 cc injectors
Old 04-20-2009, 07:10 AM
hmoobhero's Avatar
something is diffenitely wrong. itr should make around 160hp stock. those cams are alil too agressive but should not be the problem. your graph shows it stops making power after 6200rpm. just levels off til redline. kinda weird. hope you find your problem cuz that sucks.
Old 04-20-2009, 07:33 AM
mar778c's Avatar
Was vtec working?
Old 04-20-2009, 07:47 AM
Kricket88's Avatar
^^ it would almost seem it wasn't?
Old 04-20-2009, 08:12 AM
HYREV2NR's Avatar
Originally Posted by mar778c
Was vtec working?
That was my question. Sounds like it never got on the big ramps.
Old 04-20-2009, 08:46 AM
FST GSR 1's Avatar
Maybe it needs more holes in the bumper.
Old 04-20-2009, 09:26 AM
ef1.8's Avatar
smokin on dat decel
Old 04-20-2009, 09:31 AM
regamaster's Avatar
Looks like you might be restricting the motor somewhere.
Old 04-20-2009, 09:52 AM
NmaynarD's Avatar
sounded like vtec never engaged...
Old 04-20-2009, 09:55 AM
Rollo Lawson's Avatar
Was vtec working?
i didn't hear it. i sold a motor a while back and the shitty tuner left a vafc connected as he attempted to tune the maps via crome. vtec never activated through his software and the motor consistantly spat out 14xwhp. when the vafc issue was sorted, and vtec actually worked, the 1st pull was in the 180whp area
ninja edit-op, blox b's would be a much better option than the c's in ur set up
Old 04-20-2009, 10:16 AM
DonF's Avatar
142 is not bad with no VTEC.
Old 04-20-2009, 07:29 PM
UncleD's Avatar
Whaaaaa??
Old 04-20-2009, 08:25 PM
EJ1_Ex's Avatar
damn dude 141...try a different tuner..
Old 04-20-2009, 09:46 PM
Originally Posted by clean rice
Whaaaaa??
i'm honestly not suprised that ur lost....................
Old 04-20-2009, 10:10 PM
hai_tech's Avatar
stiill try figure out wat the problem,alot ppl i talk too they say cause either your cams to big or your vtec not workin,, but should i stick wit the C ?even if the vtec work would it mak alot different? would it bring up all my power,or it dont matter cause the cams to big for my setup or go wit type b? thank for the help guy
Old 04-20-2009, 10:35 PM
redGSRguy's Avatar
Get Vtec working first. Blox B's are also a good choice tho. The day before my dyno a type-r with no accessories put down 207 whp with blox b's. A local gsr put down 192 whp also.
Old 04-21-2009, 12:26 PM
UncleD's Avatar
So instead of explaining why you posted what you did, you come with a reply like this? Are you just mad at the world.....did your mom refuse you a **** or something?? I'm just confused why you would rec. the "B" when the B and C have the same vtec lobe and share very similar primaries? Damn.
Old 04-21-2009, 02:29 PM
kabaroo's Avatar
Maybe he was assuming they were just a step down in terms of "stages" for cams...
To the OP.. Do not worry about the cams, they are not going to lose the 30-40whp you are seeing. Figuring out what is wrong with your motor is step one!
Old 04-21-2009, 02:35 PM
KuEy's Avatar
damn, vtec didnt seem to have engaged like they all said. i know shane is a good tuner, cuz he tuned my LS-T, but i guess he might not know too much on N/A. try going to Jordan, he might have better knowledge on all motor. Shane knows more about boost also since he deals with his DSMs.
Old 04-21-2009, 06:59 PM
phill19's Avatar
ur vtecs not working
Old 04-21-2009, 07:40 PM
illfaded's Avatar
yeah didnt hear any crossover. go to someone who knows what vtec is. obviously this tuner doesnt know anything about these motors.
Old 04-22-2009, 06:46 PM
UncleD's Avatar
Nah, Roldo is too smart for that. He and I have "exchanged" words before, I respect the guy but I really dislike him sometimes...he and "Chillinit" like to gang-up on me
Old 04-22-2009, 09:15 PM
project dc2's Avatar
I stated to the OP that the tuner is " suspect". Hai insists they tested everything So I went ahead and confirmed that I will exchange his type C's for type B's.
However, I would not be suprised if his car still doesn't make any power after the cam change due to whatever is wrong with his vehicle.
I had recommended type C's because I know what they've done for redGSRguy and haven't seen many type B's make great power on stock bottom end. Not to say they wont make great power, but in the high 190's to low 200 ranges , I personally have not seen without a nice assortment of bolt ons that work well together.
In addition, OP stated they were more interested in top end power than anything else.
Hai, your cams shipped out today Hopefully you get the cars issues fixed and figured out.
Old 04-22-2009, 09:46 PM
hai_tech's Avatar
hopefully well solve my problem, thank again phil ,very nice guy
Quick Reply: blox type C too big for stock itr?
