Valve spring tool
Valve spring tool
I want to know what type of Valve spring compressor tool i need to get so i can remove my valves and springs. Any info or pics would be very helpful thanks.
Re: Valve spring tool
The two I would rec are a c-clamp style its more expensive but well worth it, or a lever style that will bolt to the head and you have a bar you push down on to compress the spring. Down side is trying to reassemble the keepers is kind of a bitch sometime.
www.valvemastercanada.com
Buy this ^^^
watch the video of how easy it is, and yes thats how the tool works.
I have one of those, I only use it on ohv engine though. A lot of times those are great for removal but kinda suck for install.
The one I have it dosnt fit honda heads. It butts up against the head and marks it which I don't like but you can remove all the valve springs in about a min or two.
there is a snap on version of that tool also
i personal use this
http://www.amazon.com/Schley-SCH9140.../dp/B000HATEV4
i personal use this
Purpose Built
If you are using it on a h or b series THIS is the BEST and EASIEST
http://www.euroexportinc.com/store/t...ompressor.html
JDM_SOHC
03-23-2012 01:42 PM
Fezzie
12
08-21-2006 12:49 PM
Littlegreend15
07-01-2005 08:31 AM
