b20 vtec knock question
Old 06-16-2011, 02:48 PM
kevinEJ's Avatar
Default b20 vtec knock question
sup ht my b20vtec was knocking but itll only knock when i start it..
when it idles it idles perfect no noise at all. it also knocks when i drive it about 4k rpm. can it be a rod knock?
thanks for the help
Old 06-16-2011, 03:27 PM
mouab18c1's Avatar
Default Re: b20 vtec knock question
Drain the oil and look for metal shavings.
Old 06-17-2011, 12:12 AM
kevinEJ's Avatar
i saw a bit of shavings bearings gone?
Old 06-17-2011, 12:13 AM
mouab18c1's Avatar
If you saw metal shavings then it's time for a rebuild. The more you drive it, the worse it'll get.
Old 06-17-2011, 03:47 AM
N/A
Purpose Built
N/A's Avatar
It prob wasn't that bad if it was only when it was started.
But its prob toast if you been driving on it
Old 06-17-2011, 09:42 AM
kevinEJ's Avatar
i checked all the bearings they werent spun or smashed up u think i can still save it and put it new acl race bearings?
Old 06-17-2011, 10:19 AM
1998GsRIntegra's Avatar
And hope all the clearences are good after you put them in? Now is not the time to try to be cheap. Pull it appart and find out which bearing your shavings came from.
Old 06-17-2011, 10:41 AM
kevinEJ's Avatar
so wat should i do after i found the one that it came off of
Old 06-17-2011, 11:05 AM
If its a main make sure the crank isn't scored, if its a rod, make sure the rod and crank aren't scored.
Old 06-17-2011, 02:02 PM
kevinEJ's Avatar
i checked my rod bearings the crank wasnt scored still needa check my mains
Old 06-17-2011, 05:55 PM
kevinEJ's Avatar
i wasnt driving it for long when i noticed it i was on the freeway it took me like 20 mins to go home and i barely drove it after that
Old 06-17-2011, 07:12 PM
C_Rock77's Avatar
So, you were hearing a knock, but didn't spin a bearing?
Old 06-17-2011, 09:30 PM
kevinEJ's Avatar
yeaaa
Old 06-18-2011, 05:32 AM
Is that even possible?
Old 06-18-2011, 05:41 AM
N/A
Purpose Built
N/A's Avatar
Perhaps he is hearing slap
Old 06-18-2011, 12:10 PM
Unless he is running a set of low silicon forged pistons with a large p2w clearence, I highly doubt it would be piston slap. More so though because it wasn't at start up, but rather when he was on the freeway.
Idk personally from my limited knowledge base... a knocking sound around 4k rpms is usually a rod bearing.
iwannarace
10
06-13-2015 06:14 AM
leem23vtec
11-04-2010 04:34 PM
Typeezy
08-20-2008 11:19 PM
blackhatchb20
02-14-2006 02:45 AM
untitled
06-27-2003 06:34 PM
Quick Reply: b20 vtec knock question
