b18c dyno numbers
b18c dyno numbers
what numbers should I expect out of my B18cr with tuned cam gears, one layer headgasket skunk2 high compression valves header tech header and tuned s200 and of course intake. is 200 whp possible and what would be my comression be with the mods.
Re: b18c dyno numbers (rub760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rub760 »</TD></TR><TR><TD CLASS="quote">what numbers should I expect out of my B18cr with tuned cam gears, one layer headgasket skunk2 high compression valves header tech header and tuned s200 and of course intake. is 200 whp possible and what would be my comression be with the mods.</TD></TR></TABLE>
Around 11.8ish:1. Possible? Yes. Likely? Not in this lifetime. You should be happy if you break 180whp.
El Centro, w0w, I used to pass through that place all the time on my way to Glamis...Its like an oven lined with cow ****. It stinks and its eternally hot.
Sorry, lol, I just never met anyone from El Centro
Is it true they run alot of dope thru there? I know that`s a place alot of illegals pass thru, but what about the drugs?
fuck honda-tech
15
12-18-2003 04:46 AM
