Ported P30 manifold vs Skunk2 manifold
I have a P30 intake manifold lying around and am planning/collecting parts for an 85mm sleeved/bored lsvtec. I searched on here for a couple hours about the benefits of the P30 vs. the Skunk2 and couldn't find much info. I've heard that the mid-range power with the P30 manifold is better than with the Skunk2. I'm considering sending off the P30 manifold with my head to have it ported and port-matched when the head is being ported. I'd like to hear about any experiance some of you might have with going this route.
Re: Ported P30 manifold vs Skunk2 manifold (RayB)
from experience i was able to keep, if not, improve midrange by switching to an ITR/Skunk2 manifold and drastically improve top end... i think the plenum volume of the P30 manifold is somewhat limiting the flow of air into the head compared to the plenum volume of the ITR/Skunk2 manifold... if you have the budget get the Skunk2 manifold then port match that... that will yield more satisfactory gains than just sticking with the P30...
I came across the thread where the guy dyno tested the AEBS against the ITR manifold and there was a one horsepower increase across the powerband. Anyone else think this is a good idea? If it barely outperforms the skunk2/ITR manifolds and is cheaper then it seems too good to be true. Plus in the thread I read earlier a lot of people said it looked poorly made and it took more modification to fit than the sknunk2/ITR one's. I'm gonna give it some thought tho'.
Re: (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">port an aebs manifold and you could make some siiiick gains</TD></TR></TABLE>
That's kinda what I'm thinking right now. With the money I save over a Skunk2 and a few x-tra bucks I could have it ported.
Re: (hotintegranights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotintegranights »</TD></TR><TR><TD CLASS="quote">y not just go with a aebs intake manifold they are only $150 and have made more power than both ITR/sk2 manis.</TD></TR></TABLE>
My problem lies in space. I have a B16 in a first gen crx and with the P30 manifold it is about 3/8" from the firewall as it is. Does anyone know the measurements as compared to the P30 manifold? This does seem like a good option.
Anyone on here with a setup similar to what I'm building (85 mm sleeved/bored lsvtec, about 12.5:1 compression, ported head) used a ported and port-matched P30 manifold and got a dyno to put on here. I'm not as interested in peak numbers as I am a good long steady powerband. That's why I'm wondering if a ported P30 might offer the "best" of both worlds.
EH3forlife
08-30-2010 04:46 PM
