4-1 vs 4-2-1 how big of a differance? - Honda-Tech - Honda Forum Discussion
Old 07-21-2004, 08:40 PM   #1
bunks99si's Avatar
Default 4-1 vs 4-2-1 how big of a differance?
I've searched and never found one clear and definitive answer for my question.
I'm drivin a 99Si and right now im basically doin the bolt-ons, i figure doin this will give me enough time to learn what i need to know and work on my car some to get the technical knowledge to try somethin harder down the road.
Anyway, i know the 4-2-1 is for emphasis on mid-range while the 4-1 is higher end. I've searched tons of forums and came to no definite answer, and it looks as if this forum is the most knowledagle so help me out... what would be the best choice? 421 or 41?
bunks99si is offline   Reply With Quote
Old 07-21-2004, 08:47 PM   #2
Rick Solis's Avatar
Default Re: 4-1 vs 4-2-1 how big of a differance? (bunks99si)
depends on the aplication... street/drag/1.6/1.8/2.0/2.0+
for a street B16 Id recomend a good 4-2-1
Rick Solis is offline   Reply With Quote
Old 07-21-2004, 08:50 PM   #3
bunks99si's Avatar
daily driven street driven b16a2, would probably never see a track unless i got some "real" work done.
Old 07-21-2004, 08:59 PM   #4
Lysawy's Avatar
Default Re: (bunks99si)
For daily use on street 4-2-1 has better ground clearence for lowered cars...
but 4-1 should flow better
Lysawy is offline   Reply With Quote
Old 07-22-2004, 07:15 AM   #5
JDMSiGuy17's Avatar
You SHOULD get better mid-range power from the 4-2-1 header and more top-end power from the 4-1. I have a 4-1 on my Si and feel like it gave me more mid-range power. It all depends on what you plan on doing to your car. Good Luck
JDMSiGuy17 is offline   Reply With Quote
Old 07-22-2004, 07:21 AM   #6
B20JonLee's Avatar
I can't comment on how this swap would affect other blocks however I had a DC 4-2-1 and swapped out for the DC 4-1 and WOW what a difference. I gained 7 hp at peak but more impressive was my ELEVEN lb. ft. of torque at 4500 rpm. I found nothing but gains going to this header. This may be a result of having a port matched intake manifold and a p&p head on my B20vtec, but just looking at the tube diameter and bends the new header flows WAY better than my old one.
B20JonLee is offline   Reply With Quote
Old 07-22-2004, 07:33 AM   #7
WAFFLES's Avatar
4-1
WAFFLES is offline   Reply With Quote
Old 07-22-2004, 08:04 AM   #8
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: 4-1 vs 4-2-1 how big of a differance? (Manuel)
with this setup what should i run
b16 Dh-racing head Port and Poilsh
-ericking racing 68mm throttle body
-ib spec dual springs
-rev valves
-rev retainers
-jun 3 cams
-toda cam gears
-arp head bolts
-skunk 2 intake manifold
-j's racing intake with custom air ventalation to bumper
-Smsp header no cat to hks universal muffler
b18b1 block
-sleeving
-ib spec super doopers 86mm
-ls crank
-ib spec rods
-arp rod bolts
-z10 griddle
-custom oil pan
-itr tranny
-hasports hrydo to cable convo
Old 07-25-2004, 10:48 PM   #9
Lysawy's Avatar
Default Re: 4-1 vs 4-2-1 how big of a differance? (FastAllmotorLsVtec)
cheap setup for you JDM 4-1 2.5' or ITR
otherwise look into hytech or an-r or other custom companies
Old 07-25-2004, 11:18 PM   #10
Chopper 2 Hopper
justBLZE's Avatar
Default Re: 4-1 vs 4-2-1 how big of a differance? (Lysawy)
Save up and get something custom.
justBLZE is offline   Reply With Quote
Tags
2002, 41, 421, altima, b16, b20, block, griddle, h22, headers, nissan, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
