///// Calling all MOTOR GURUS//////
okay here it is guys i chated with my friend and explained to him that there is no way you will see 12s in this set-up in an EK now this is for the people who have similar set-ups and have done it in an EK. NOT EG-ef- but in an EK
skunk2 stage2 cams,hondata and i/h/e clutch and flywheel)..and if i add CTR piston's standard bore and a Nice Stage2 head port and polish would i see hit 12's with slicks elevation is 2000 feet above sea level
here is what i told him what to do sleeve the block eagle rods,aeries pistons comp12.5,knife edge crank,so basicly i told him to go 2.0 now which would you do or have do and seen 12s in an EK hatch
then he told me that his buddy did a 12.8 in a bone stock gutted eg with an itr motor which i also called bullshit on so you guys help this man out
Modified by 1Quikgsr at 9:59 AM 2/21/2005
Re: ///// Calling all MOTOR GURUS////// (1Quikgsr)
to see 12's with slicks in an all motor setup in a hatch you need to be making serious power. probably 220+ at 2000ft. It all depends on tuning, but I dont think there is any way with I/H/E on an ITR motor than you will ever see 12's even at sea level. Youll lose a few tenths at 2000ft of elevation, probably 1/2 of a second IMO
F*CK THIEVES!
Re: ///// Calling all MOTOR GURUS////// (PhatAcuraIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra »</TD></TR><TR><TD CLASS="quote">to see 12's with slicks in an all motor setup in a hatch you need to be making serious power. probably 220+ at 2000ft. It all depends on tuning, but I dont think there is any way with I/H/E on an ITR motor than you will ever see 12's even at sea level. Youll lose a few tenths at 2000ft of elevation, probably 1/2 of a second IMO</TD></TR></TABLE>
yea..exactly, its gonna have to be fully built to see 12s. stock ITR with I/H/E in and EK..youll still be in the low 14s doggiee
u should go into the drag racing section to ask a question like this.
im fairly educated about n/a motors, but i really dont have too much comprehensive knowledge regarding hp/weight/height ratios and how they effect 1/4 mile times.
shrug
shrug
Re: (kaptr1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaptr1d »</TD></TR><TR><TD CLASS="quote">u should go into the drag racing section to ask a question like this.
shrug
exactly what he said.
shrug
Re: ///// Calling all MOTOR GURUS////// (hasback_00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hasback_00 »</TD></TR><TR><TD CLASS="quote">yea..exactly, its gonna have to be fully built to see 12s. stock ITR with I/H/E in and EK..youll still be in the low 14s doggiee</TD></TR></TABLE>
an itr with those mod will run lower than a low 14 with slicks in a ek... unless alot of people can't drive......i have a friend with a itr in a ek with i/h/e tuned with a vafc making around 180 and he runs 13.8-13.9 on street tires in a ek.... in a eg u only need around 200whp to run 12's i've sen it done many times on slicks ......my buddie has a eg that made 144 onthe motor and he had a 65 shot on it which woudl be around 200 and he ran a 12.71 on 22" slicks..... this is with a really good driver also.......
With the first setup u listed 12's my be possible with slicks , if tuned properly , i dunno how much ur elevation is gonna affect that, and it also depends on how much crap he has in his car weights. my stock ek is 2300
Re: ///// Calling all MOTOR GURUS////// (ReDHaTcHy97)
is it possible to hit 13.5 with a b16 block, b16 head, skunk stage 3s, upgraded valvetrain, CTR pistons, mugen head gasket, flat valves ( aproximatly 12.2:1 CR), CAI, 2.5" exhaust, JDM 4-1 header 2.5", carsound cat, with lightwieght flywheel and CM stage 2 clutch, chipped p28...all in a EM1 full interior?
Re: ///// Calling all MOTOR GURUS////// (Honda_b16a2)
I have personally watched a 99 civic ex coupe with a stock C5 with Hondata s100, open header on slicks run consistent 13.5's(no weight removal). My homeboy with a stock sir2 swap in his dx eg hatch, with lsd, ran 14.1's on shitty street tires.....but he can really drive.
geoscranny84
03-30-2007 10:32 AM
