how do i get more power for my 1st gear
my 1st gear is not all that great but 2nd and above kickass. what do i need to get to make my 1st gear abit quicker . i got a poormans type r with a b16 tranny
Re: how do i get more power for my 1st gear (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">i got a fever, and the only cure is more cowbell!</TD></TR></TABLE>
really.....?
really.....?
Re: how do i get more power for my 1st gear (B18TurboEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18TurboEF »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
ROFL
Try a set of BFG drag radials to avoid spinning. Or an LS tranny, if you want you can take my YS1 LS tranny and i can take you b16 tranny .
ROFL
Re: how do i get more power for my 1st gear (envision2teg)
yea cowbell . i guess u guys dont know sense u posted that up. i though this form had ppl that know there **** but i guess not .
Re: how do i get more power for my 1st gear (95eg6allmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95eg6allmotor »</TD></TR><TR><TD CLASS="quote">yea cowbell . i guess u guys dont know sense u posted that up. i though this form had ppl that know there **** but i guess not .</TD></TR></TABLE>
Its called a thread hi-jack...
Do you just not have any traction, or what?
Re: how do i get more power for my 1st gear (LSVTEC 91 Civic)
thank u finally someone. i got good traction i launch the car at about 2500 rpm and it seems like i have power loss though first. but when i get into 2nd it changes and i get a **** load of power. i was wondering sense i did a poormans type r i still have the gsr harness on the motor. do i have to disconect anything? thank u for responding
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95eg6allmotor »</TD></TR><TR><TD CLASS="quote">thank u finally someone. i got good traction i launch the car at about 2500 rpm and it seems like i have power loss though first. but when i get into 2nd it changes and i get a **** load of power. i was wondering sense i did a poormans type r i still have the gsr harness on the motor. do i have to disconect anything? thank u for responding </TD></TR></TABLE>
B16 transmissions have exteremely short 1st gears, I don't really understand how you have no power in 1st.. Are you positive its a B16 tranny?
Harness has nothing to do with transmission gearing.
yea i'm positive its a b16 tranny i saw it get taken out of a stock 00 si at the junker. i heard something about a secondary butterfly or somethink i have to disconnect? i have egs with d16 stay up with me though my launch
Re: how do i get more power for my 1st gear (97L-esVeeTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg »</TD></TR><TR><TD CLASS="quote">hows your clutch??? is it slipping?</TD></TR></TABLE>
It would be slipping more in 2nd than in 1st.....
What speed are you going at 8k rpm in 1st gear?
Where rpm do you shift at, and what is the rpm drop to 2nd?
the clutch grips pretty good. i'm going to try what you guys were saying. my tires grip good, but i'm just going to test it out. i'm going to borrow some slicks and see if thats the problem.
If theres no power in 1st, and alot of power in 2nd, than theres gotta be MAAAAD 3rd GeaAAAR VtaAAAAAAAK!
Re: how do i get more power for my 1st gear (Black R)
my first gear goes up to 40mph, and the rpm drops around i'd say some were between 5-6k rpm, and i shift around 8100k
in that case, 1st gear is NOT your problem.
What is your launch technique and rpm?
Try launching at 3k and see how that feels.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
Harness has nothing to do with transmission gearing.</TD></TR></TABLE>
correct me if I am wrong, but don't all b-series manual transmissions have the same 1st gear?
Re: how do i get more power for my 1st gear (AllMotoRex)
the reason 2nd gear picks up so fast is because when your shifting from 1st to 2nd, your already in vtec when you shift into 2nd. (Almost). When you are at close to 8k, and pull a quick shift into 2nd, your rpms are gonna already be between 45 and 5. vrec kicks in at 5.2 for you i believe which means you dont have to deal with the lag bullshit before vtec. Your already there. It is hard to explain, but does anyone know what i mean? If you were to launch from around 4.5 or 5, your get a killer launch and 1st would pull harder than 2nd, but thats a great way to burn out your clutch. Thats just my .2.
Re: how do i get more power for my 1st gear (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power »</TD></TR><TR><TD CLASS="quote">
correct me if I am wrong, but don't all b-series manual transmissions have the same 1st gear?</TD></TR></TABLE>
no, obviously the final drives are all diferent on different trannys but the b17 tranny actually had a shorter first (not that you would really want that, they sell taller firsts from ATS for a reason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotoRex »</TD></TR><TR><TD CLASS="quote">****.. thast some krazy first gear 40 mph? maybe you have some type of hybrid trans?</TD></TR></TABLE>
first gear at 8100 rpm in a b16/USDMR tranny is 39 mph so no its not a custom tranny
