Safe to rev to 9K on stock retainers?
Old Sep 8, 2005 | 08:22 PM
Junkyard2000's Avatar
Default Safe to rev to 9K on stock retainers?
Im running skunk2 stage 2 on skunk springs, but stock retainers. Still need to tune, but say i keep making power to 9K, will that be ok on the stock retainers? I dont mind spending the 150 on new retainers but if i dont really need them then its a waste.
Old Sep 8, 2005 | 08:24 PM
Stein's Avatar
Default Re: Safe to rev to 9K on stock retainers? (Junkyard2000)
I THINK the main advantage of TI retainers is less weight, but they can wear fast.
Old Sep 8, 2005 | 08:31 PM
Default Re: Safe to rev to 9K on stock retainers? (Stein)
theyre stronger. Stock ones can break, especially under high revving. Only thing is with the ti you need to replace them more often.
Old Sep 8, 2005 | 09:13 PM
Hamstr323's Avatar
dude at 9000 you are pushing it ALOT just buy aftermarket valve springs & ret! trust me save yourself the trouble of a blown motor when you dropped a valve because you broke a stock retainer...
Old Sep 8, 2005 | 09:27 PM
Default Re: Safe to rev to 9K on stock retainers? (Hamstr323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">dude at 9000 you are pushing it ALOT just buy aftermarket valve springs & ret! trust me save yourself the trouble of a blown motor when you dropped a valve because you broke a stock retainer...</TD></TR></TABLE>
yea already got the skunk2 valve springs in. It just seems like a hassle to put in new retainers and the shop will probly charge a grip. I guess a small price to pay for the potential damage.
Old Sep 8, 2005 | 09:47 PM
trustbuddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote">yea already got the skunk2 valve springs in. It just seems like a hassle to put in new retainers and the shop will probly charge a grip. I guess a small price to pay for the potential damage.</TD></TR></TABLE>
exactly.
Old Sep 8, 2005 | 09:54 PM
99skunkedSi's Avatar
Default Re: Safe to rev to 9K on stock retainers? (trustbuddy)
i would replace the stock ones, it probably wont cost you more than 300 for retainers and install
Modified by 99skunkedSi at 11:04 PM 9/8/2005
Old Sep 8, 2005 | 09:56 PM
hitvtecgetloud09's Avatar
Default Re: Safe to rev to 9K on stock retainers? (99skunkedSi)
wow 9000 is a pretty risky rpm..im running on ctr with itr valve train and i dont take my **** past 8200...just cuz im a low baller and i dont wana **** **** up
Old Sep 8, 2005 | 10:06 PM
you probably aren't make power up to 9k anyway. tuning will most likey prove that. let us know once you get it tuned!! g/l
Old Sep 8, 2005 | 10:07 PM
Kendall's Avatar
You won't have any problems at all at 9000 rpms with stock retainers. The stock ones are indeed quite good. It's true that there are better, but it's not that critical if you're only going to 9k. Consider upgrading to the aluminum retainers used in the early automatic B16's if you want to upgrade.
Old Sep 8, 2005 | 10:26 PM
boostinCX's Avatar
Don't ask me what my buddy was doing at 9'500 but a retainer broke and dropped a valve in his newly installed ITR swap... DOOOHHH!!!
Old Sep 8, 2005 | 10:37 PM
Default Re: (boostinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinCX &raquo;</TD></TR><TR><TD CLASS="quote">Don't ask me what my buddy was doing at 9'500 but a retainer broke and dropped a valve in his newly installed ITR swap... DOOOHHH!!!</TD></TR></TABLE>
i once accidentally revved to 10k in my b16 and was ok, but i had sk2 s/r. one of the reasons i suggest changing them.
Old Sep 9, 2005 | 12:07 PM
hondaxsimike's Avatar
my buddy cracked 2 retainers at 9k so i wouldnt reccommend taking it over 8500 without the risk of fukin somethin up man. i have the skunk2 ti retainers in mine and ive taken it to 9500 on stock bottom end. but i dont really reccommend that
either unless youre balsy or stupid.
Old Sep 9, 2005 | 01:02 PM
reactiondc2's Avatar
Default Re: Safe to rev to 9K on stock retainers? (hondaxsimike)
from my experience 9k shouldnt be a problem for stock retainers...i ran my engine up to 9500 with jus rocket gen2 springs without problems and my friend revs his car up to 9k all the time with jus rocket springs
Old Sep 9, 2005 | 02:01 PM
DavidR's Avatar
stick to stock. Ti retainers wear out and will have to be replaced. My set wore down in 40k, and not evenly. The thinnest ones were 1/2 the thickness of the thicker ones, and THOSE had worn too. It is hard to take a pic of the wear, I'll see if I can't get a set of caliper gauges to show the wear.
Old Sep 9, 2005 | 02:07 PM
Malgerus's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You won't have any problems at all at 9000 rpms with stock retainers. The stock ones are indeed quite good. It's true that there are better, but it's not that critical if you're only going to 9k. Consider upgrading to the aluminum retainers used in the early automatic B16's if you want to upgrade.</TD></TR></TABLE>
Wow, this is news to me. You always hear horror stories about the first gen auto heads... weak single valvesprings, and this and that. Their retainers are better than the M/T version?
Old Sep 13, 2005 | 04:13 AM
oldskool teggy's Avatar
Default Re: (Mr. S)
just lighter. but steel and aluminum is an equal strength to weight ratio
Old Sep 13, 2005 | 09:58 AM
DonF's Avatar
Default Re: (Oldskool teggy)
How old are your stock retainers? That is the question.
Old Sep 13, 2005 | 10:03 AM
Rocket's Avatar
Default Re: (DonF)
B retainers are fused powdered metal. Honda switched to forged retainers on the K.
Just a piece of info for you guys.
Old Sep 13, 2005 | 11:38 AM
JDMlyfestyle's Avatar
my Stock ITR valvetrain on my b16 block took 9500 for 2 years i know rev to 8500
Old Sep 15, 2005 | 08:07 PM
Default Re: (JDMlyfestyle)
im just gonna wait till i dyno
Old Sep 15, 2005 | 08:22 PM
an2ny888's Avatar
Default Re: (Junkyard2000)
early b16's had aluminum retainers? can anybody else verify this? if so then it would be a good low cost upgrade
Old Sep 15, 2005 | 11:48 PM
mpd076's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">How old are your stock retainers? That is the question.</TD></TR></TABLE>
My stock retainers are 4.5 years/37,000 miles old, and I have the same question as thread starter. Of course I can inspect the retainers at the point of installing the new cams, but what would be the average age/mileage stock retainers are good for?
Old Sep 16, 2005 | 09:43 AM
ShaunRR's Avatar
HT White Ops
Community Builder
I'm not a fan of using stock retainers with aftermarket cams. I have seen them break far too often. I'm not saying that they are going to break, or even that it is likely, but it is definitely a distinct possiblity. Not worth the risk IMO.
Ti retains can last quite a long time, depending on the design.
Old Sep 16, 2005 | 04:29 PM
Default Re: Safe to rev to 9K on stock retainers? (rochesterricer)
dayam i just got a quote to install the retainers $300. Dont wanna fork out $450 if i dont have to. IM not sure how old the retainers are since they were on the car when i bought it.
