Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video
Here is a video of Power Rev Racing 1997 EK hatch with JDM H22 engine. The motor is stock except for bolt ons.
191 Hp @ 7400rpm
155 TQ @5400rpm
Will try and scan the dyno sheet. But it kind of got messed up as this dyno run was sometime last year. The dyno pull was done in 4th gear.
http://www.we-todd-did-racing....5NTQx
191 Hp @ 7400rpm
155 TQ @5400rpm
Re: Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video (SohcPower)
Video gives me a message that windows cannot open the fiel type and wants me to websearch for the correct program. Which is pretty strange considerign its an AVI file.
Re: Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video (xEnderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx »</TD></TR><TR><TD CLASS="quote">Video gives me a message that windows cannot open the fiel type and wants me to websearch for the correct program. Which is pretty strange considerign its an AVI file.</TD></TR></TABLE>
works for me, opens quicktime, but im using a mac.
You need divX. As I used DivX to compress it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcPower »</TD></TR><TR><TD CLASS="quote">what mods, ? Tuned?</TD></TR></TABLE>
Just bolt ons. (Euro R Intake Manifold, JG 65mm Throttle Body, Carbon Intake, Cheap header with modded 2.5 in collector, and Buddy Club Exhaust.
Not tuned. Its a chipped P28
Re: Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video (Power Rev Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing »</TD></TR><TR><TD CLASS="quote">Just bolt ons. (Euro R Intake Manifold, JG 65mm Throttle Body, Carbon Intake, Cheap header with modded 2.5 in collector, and Buddy Club Exhaust.
Not tuned. Its a chipped P28</TD></TR></TABLE>
Darkknight on this board made 197/156 on that similar set-up, but ANR, stock TB.
I threw together a base map for it, it was only street tuned.
I would like to see the dyno sheet if you post it.
Re: Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video (Turbogixxer)
those are some good numbers, I dont wanna bring in the b18c(r) into this but with bolt ons does it put out similar numbers? All I hear is how the b18c is more powerfull etc...
B18c might make about same hp but about 20 ft lbs of tq less. Which would make the h22 faster. only thing that kills the h22 is the bad gear ratios
If u could do your swap over would u still go h22? ANy dissapointments, I mean u got some great numbers...but numbers arent always everything.
Have u been to the 1/4track with yours?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcPower »</TD></TR><TR><TD CLASS="quote">If u could do your swap over would u still go h22? ANy dissapointments, I mean u got some great numbers...but numbers arent always everything.
Have u been to the 1/4track with yours?</TD></TR></TABLE>
If I was to do it again I would of done a K. But I would not do a B series over a H ever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcPower »</TD></TR><TR><TD CLASS="quote">those are some good numbers, I dont wanna bring in the b18c(r) into this but with bolt ons does it put out similar numbers? All I hear is how the b18c is more powerfull etc...
It's very unlikely. Most c5s are in the 170 - 180s w/ bolt ons and tuning.
Get it tuned and a better header and you will definitely make more power!
Re: Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video (DarkKnight1)
hey how'd you keep the secondaries with the P28, I thought you could only run the secondaries with the P72?? Please tell me cuz I have a H22 with chipped P28 and there is not any secondaries. I was told to get the P72.
Re: Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video (H22JDMEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22JDMEG »</TD></TR><TR><TD CLASS="quote">hey how'd you keep the secondaries with the P28, I thought you could only run the secondaries with the P72?? Please tell me cuz I have a H22 with chipped P28 and there is not any secondaries. I was told to get the P72.</TD></TR></TABLE>
Never had secondaires. I was running a Euro R Intake Manifold
No secondaries in the EuroR, but you can have just about any OBD1 vtec ecu control secondaries. The boards are all nearly identical. pm: Turbogixxer he'll get you setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing »</TD></TR><TR><TD CLASS="quote">only thing that kills the h22 is the bad gear ratios</TD></TR></TABLE>
H2B
H2B
98vtec
04-09-2006 09:54 AM
accordfreak
12-14-2003 12:06 AM
