what rods to use for LS/VTEC?
should I upgrade the stock LS rods? or are they ok to re use?
are ITR rods the same length? will they work instead of the LS rods? or are the only rods that can replace the ls rods aftermarket?
thanks.
thanks.
Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">all b series rods are diff. length. except for b20 and ls rods, they are the same. if you plan on going aftermarket, got them for an LS.</TD></TR></TABLE>
upgrade beefy rods!
upgrade beefy rods!
Re: (clean rice)
LS rods work fine. juss get some ARP bolts and ur good to go. i have stock LS rods on my Ls/V and i take her up to 8100 almost 3 times a day.
Re: (Dan Ruddock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan Ruddock »</TD></TR><TR><TD CLASS="quote">If you plan on running oem pistons you have to run ls rods. Dan</TD></TR></TABLE> unfortunately true
