Post you poor man type r set ups
Old Mar 22, 2006 | 01:26 PM
vtec99's Avatar
Default Post you poor man type r setups
Like title says I want to see what cams most of yall guess went with.Im in the process of getting cams. I would like to see bore size and compression and what cams and power made,injector size.
Old Mar 22, 2006 | 11:07 PM
vtec99's Avatar
Dam you people
Old Mar 23, 2006 | 04:09 AM
Nick M's Avatar
Default Re: Post you poor man type r setups (vtec99)
Wouldnt a poor man's type r have CTR or ITR cams?
Just a wild guess....
Old Mar 23, 2006 | 04:23 AM
jeremy.'s Avatar
i had a gsr block with jdm itr pistons, b16 head with itr intake manifold. never got to build the motor cause the car was stolen
Old Mar 23, 2006 | 04:27 AM
UncleD's Avatar
Default Re: Post you poor man type r setups (ekay_jeremy)
I hate the term "poor mans type r."
Old Mar 23, 2006 | 05:43 AM
DJ_NeX's Avatar
GSR bottom end
Endyn Pistons/Eagle Rods
Balanced
Type-R Head w/ basic i/h/e
Oversized Valves
Portflow Valvetrain
B16A1 Cams
170 hp 135 tq tuned on Hondata s100
Old Mar 23, 2006 | 08:13 PM
vtec99's Avatar
Default Re: Post you poor man type r setups (clean rice)
Anybody else?
Old Mar 24, 2006 | 12:05 AM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">I hate the term "poor mans type r." </TD></TR></TABLE>
What in the heck is a 'poor mans Type-R' ?
Old Mar 24, 2006 | 03:41 AM
RagingAngel's Avatar
Default Re: Post you poor man type r setups (1997ITR122)
Generally accepted as a GS-R shortblock with a 16A head and ITR cams/manifold
There appear to be several variations....
1) 18C1 block with ITR (JDM or USDM) pistons and 16A head + ITR cams/wutever manifold
2) 18C1 block with ITR (JDM or USDM) pistons and complete ITR head
etc...etc....
I'm sorta "consulting" for "1."
Old Mar 26, 2006 | 11:13 AM
vtec99's Avatar
Dam I guess Im going to be one of few on here with this motor setup lolol.
Old Mar 26, 2006 | 01:47 PM
DJsilkyjr's Avatar
i had a gsr block, type r pistons, b16 head with b17 cams, i/h/e, chipped p28 ecu, b16 trans, 178whp 132 torque on a dynojet
Old Apr 2, 2006 | 06:27 PM
longuyen88's Avatar
im in the process of building a poor man's itr.
I am using a 94 gsr block with a b16a2 head w/ itr intake cam, gsr exhaust cam. skunk2 mani, itr throttle body, and rsr exmag exhaust.
I want to use aftermarket forged pistons w/ 10:1 compression, and aftermarket forged rods. I am only going with 10:1 because I may turbo it later on, and 10:1 seems to be a happy medium between boost and NA.
Oh, and new obd2 oil pump, gsr water pump, arp rod bolts, and arp head bolts. Should be a good platform for 350+ HP if I want to boost later on.
Old Apr 2, 2006 | 10:14 PM
GEIJIN's Avatar
Default Re: (DJ_NeX)
umm those #'s seem a little low for your settup
Old Apr 2, 2006 | 10:33 PM
Jradrebel's Avatar
Default Re: (GEIJIN)
I have GSR, lsd b16 trans, ITR R cams, Skunk 2 mani, ITR header, password JDM intake, RSR exhaust... 160whp
Old Apr 2, 2006 | 11:42 PM
sal's Avatar
sal
Default Re: (Jradrebel)
Mine has a GSR block with 11.5:1 CP pistons, Eagle rods, b16a2 head with no portwork, Skunk2 springs and retainers, Buddy Club spec 4 cams, Skunk2 intake mani, DCsports 4-1 JDM 4-1 header, 2.5" exhaust, ITR Trans. Not sure how much power it makes, its not tuned yet. So far its best was a 13.5 @ 99 running on a chipped p28. I'm hoping for either 200whp or a 12.9 1/4 mile with a much better header and neptune.
Old Apr 3, 2006 | 12:25 AM
fmrprojects's Avatar
Default Re: (sal)
look for DSRXNATE. hes one of my homies adn he has a poor mans puutting out 200hp 133tq. his is Gsr block with p30 pistons, DNR ported b16 head with blox type b's
Old Apr 3, 2006 | 04:50 AM
Nick M's Avatar
Default Re: (fmrprojects)
a "poor mans type r" contains honda parts...
Old Apr 3, 2006 | 06:32 AM
Uncle Willie's Avatar
Default Re: (Nick M)
Sorry to sort of thread jack, but what is the point of putting a b16 vtec head on a gsr bottom end? Does it bump up compression a tad? If so, by how much. Does it flow better? I have no idea. Someone please help me out. Im confused.
I would really like to know.
Old Apr 3, 2006 | 07:00 AM
Han Solo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">a "poor mans type r" contains honda parts...</TD></TR></TABLE> thats exactly what i thought. GSR bottom end with ITR pistons. b16 head with ITR cams.
Old Apr 3, 2006 | 06:56 PM
longuyen88's Avatar
Default Re: (KINGSOL18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KINGSOL18 &raquo;</TD></TR><TR><TD CLASS="quote"> thats exactly what i thought. GSR bottom end with ITR pistons. b16 head with ITR cams.</TD></TR></TABLE>
well then what do you call a built b16c1 block and b16a head? frankenstein? that would be ls/vtec
Old Apr 6, 2010 | 11:13 PM
Jdmefsir12's Avatar
Default Re: Post you poor man type r set ups
wats up my set up is a jdm gsr block crower rods 20. over itr pistons ls crank itr oil pump water pump ys1 trans 6 puck sprung action clutch 11.5 clutchmasters fly wheel lsd... b16a2 head port and polished by the homie ricky both exhaust and intake side and port and polished tb and intake manifold super tech vale train buddy club spec 3 cams buddy club cam gears blox manifold erics racing tb aem fuel rail and reg... greddy timing belt...... arp head bolts acel bearings
tuned on chrome made 237 to wheels on 91 pump gas
Old Apr 7, 2010 | 12:34 AM
Ek-Xang's Avatar
OK, me and my buddy just got done building a poor-man type r but after driving it the motor seem to feel like there is a major power loss on top end. I've check the compression but it seems like I'm not getting the right psi for the piston that I've put in. Am I leaking compression anywhere? or did i not torque the head down right? A torque spec would also help just in case that i didn't torque down the head right. Any info would help out a newbie like me thank you. Here is a list of the build.
-B18C1 bottom block
-B18C1 Crank
-B16?? cylinder head (stock)
-Jdm ITR Piston (standard oem size)
-Stock Gsr injector
-Gsr timing belt
Old Apr 8, 2010 | 01:28 AM
Since 1983's Avatar
B18C1 block
-Wiseco 12:1 compression pistons
-Eagle rods
-type r valvetrain
-270cc injectors
-70mm throttle body
-aem intake
188whp on dynopacks
Old May 30, 2010 | 01:57 PM
revlimitsoljah's Avatar
i'm putting together a 95 gsr block with 00 usdm itr pistons 00 b16a2 head with 00 gsr camshafts and using a p2t computer for now. hopefully it makes decent power for a daily driver.
Old May 30, 2010 | 04:40 PM
CreeWorks's Avatar
-B18c1 block (stock pistons)
-B16 head (stock 99si)
-ITR intake manifold w/TB
-some ebay intake & DC 4-1
-chipped PR3, LS cable trans
-90' ef DX hatch
14.1@100
no dyno
that motor was a good little beater thou....lasted a while till the driver side mount bracket broke.
