Buying an LS block tomorrow....need help.
the motor is from a 93 teg. i think the engine code is b18a (correct me if i'm wrong). i need to know if it comes with a cable or a hydro tranny, and if it does come with a cable tranny could a hydro be swapped in its place. please give me any info you got. i was planning on doing a b16 swap, but i'm getting a good deal on this motor($200.00 motor & tranny), so i donn't want to pass this up if it is worth it. thanks in advance for any help.
Re: (92b16vx)
Yeah, you can use a hydro tranny on the MOTOR with no problem as long as yoru CHASIS is designed for it. If not then you can buy the adaptor plate from HAsport.
