what kind of harness is this
wiring harness that is....he said its a 98 itr...is it? not sure if you can tell by the pics
my main problem is that the injector clips arent fitting the injectors...i need to know what i need to replace..my injectors or my harness
any info appreciated! thnx
Re: what kind of harness is this (neeks)
That appears to be a 94-95 harness that someone has changed the distributor plug on, although I didnt see the alternator plug to compare as well..
check out the green plug in one of those pics........ thats the vtec solenoid plug..... so its a gsr....... not sure about the year though
Re: what kind of harness is this (cjames235)
well
it has vtec plugs so at least a vtec harness,
has obd1 injector clips
with obd2 dizzy harness
looks like a chopped up harness to me
Re: what kind of harness is this (slow90hatch)
looks alot like a 92-95.
what are the ECM connections?
and all you have to do is get some Plugs that fit your injectors and wire them on there as long as your ECM works...
Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">wont obd2 have 2 o2 sensors?</TD></TR></TABLE>
not in the engine harness....... the second o2 plug comes from the dash harness
