What is code 22 on an obd-0 b16a?
Old Apr 24, 2005 | 04:54 PM
white91rex's Avatar
Default What is code 22 on an obd-0 b16a?
I am getting a code 22 ( 2 long flashes and 2 fast flashes). I have just finished the swap. It is in a 1990 crx si. I am using the hasport v-tec harness.
-chris
Old Apr 24, 2005 | 06:54 PM
thepriceiswrong's Avatar
Default Re: What is code 22 on an obd-0 b16a? (white91rex)
22* VTEC Oil Pressure Switch defective circuit or unplugged
defective oil pressure switch
Old Apr 25, 2005 | 03:25 AM
white91rex's Avatar
Default Re: What is code 22 on an obd-0 b16a? (thepriceiswrong)
Thank you for the reply. Do these switches go bad often? This is the switch right near the temp sensor and v-tec switch correct? Does it just unscrew out? When I go to honda, Will a v-tec oil sensor switch from a 94 del sol v-tec ( w/b16) fit? That car is obd 1, is their a diffrence?
-chris
Old Apr 25, 2005 | 08:43 AM
1fastvik's Avatar
All vtec oil switches will work. Be sure to check you grounds.
mike_h22a1/cd5
Oct 20, 2013 02:15 AM
wernhersey
Apr 15, 2007 07:48 AM
cioli
12
Feb 26, 2006 08:31 AM
drudy
Aug 26, 2005 12:20 PM
drudy
Aug 7, 2005 05:59 AM
