question about b16a engine with type r head?
Old Apr 26, 2005 | 09:57 PM
hnoppenberger's Avatar
Default question about b16a engine with type r head?
im new to hondas, i am a bmw tech and looking to have some fun. anyways
ive heard it possible to put a b18c engine head onto a b16a block. is this true?
any modifications needed for this?
also, would intake manifolds and exhaust manis/ headers fit up to the new head, or would i need type r intake/exhausts? would the b16 distributor fit up as well?
im guessing it shouldnt be a big deal becuase a b18 is a stroked b16 am i correct?
Old Apr 27, 2005 | 11:50 AM
Default Re: question about b16a engine with type r head? (hnoppenberger)
neone?
Old Apr 27, 2005 | 01:41 PM
slammed00si's Avatar
the head will fit.
no a b18 is not a stroked b16.
Old Apr 27, 2005 | 06:58 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hnoppenberger &raquo;</TD></TR><TR><TD CLASS="quote">im new to hondas, i am a bmw tech</TD></TR></TABLE>
I'm an M3 fanatic so that's ok in my book
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hnoppenberger &raquo;</TD></TR><TR><TD CLASS="quote">ive heard it possible to put a b18c engine head onto a b16a block. is this true?
any modifications needed for this?</TD></TR></TABLE>
Direct bolt-on, no mods needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hnoppenberger &raquo;</TD></TR><TR><TD CLASS="quote">also, would intake manifolds and exhaust manis/ headers fit up to the new head, or would i need type r intake/exhausts? would the b16 distributor fit up as well?</TD></TR></TABLE>
The B18C5 and JDM ITR (B18C) use a B16A head casting. Of course the cams, valvetrain, etc. and the factory port/polish job sets them apart from the B16 heads. The manifolds and distributor will interchange. The B18C1 (GSR) is different and it's intake manifold will not fit the B16A/ITR head and vice versa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hnoppenberger &raquo;</TD></TR><TR><TD CLASS="quote">im guessing it shouldnt be a big deal becuase a b18 is a stroked b16 am i correct?</TD></TR></TABLE>
It's not a big deal for the head swap, but a B18 is not a stroked B16 as mentioned
Old Aug 22, 2005 | 03:32 PM
For_Sale's Avatar
Default Re: question about b16a engine with type r head? (VTECVillain)
what's the benefit//power range gained?
Old Aug 23, 2005 | 08:28 AM
reactiondc2's Avatar
Default Re: question about b16a engine with type r head? (guest16)
if you go with a b18c1 head then you will see a .2 raise in your compression...if you go with a b18c5 head then you will get a mild bit of porting in the bowl area along with undercut intake valves and some better springs but compression stays the same
Ls_Turboteg
Sep 9, 2008 08:27 PM
paddy b
Jul 18, 2007 09:49 AM
h22acivicman
Sep 30, 2004 01:49 PM
compwc18
May 20, 2004 01:19 AM
conceptEG
Sep 4, 2003 11:45 AM
