skunk intake manifold for 1st gen. b16a
does anybody know what parts or mods. are needed to install a skunk manifold in a 1st gen. b16a. my main concern is the iac valve,fast idle valve,fuel rail etc.
No your fuel rail will not line up like stock! On the first gen the fuel pressure regulator is in the middle of the fuel rail. If you put it on your new manifold your fuel pressure regulator will hit the sensor. You need to get a newer fuel rail to make it work. Also on the 1st gen b16s the FITV was made onto the Intake manifold but the 2nd gen b16 had a slightly larger throttle body with the FITV made onto it. So you either have to bypass the FITV or get a newer throttle body.
if you have any questions feel free to pm me
later
Matt
later
Matt
JG90CRX-Si
02-03-2005 06:28 PM
irev210
04-03-2003 08:05 AM
EVOCELICA
12-11-2002 10:31 PM
