B16 in DA Axles
Old Apr 26, 2005 | 08:09 AM
2manycars2choose's Avatar
Default B16 in DA Axles
Ive searched, so sorry before hand. The shop gave me the wrong axles the first time. So the 2nd time I asked for 99/00 Si axles for a b16/j1 tranny in a 92 DA. Will this work? After searching I found lots of info for EG's but not too much for DA's. And I did search in the sticked "swap" thread.
Edit:
The reason I ask is because I am in the middle of replacing the axles and the passenger side I managed to use a (as napa calls it) "1.8 integra axle" but on the passenger side the end that goes into the hub was way too thick to fit into the hub and it didnt even look the same as the one I pulled out. Which is why when I went back I asked for 99/00 Si axles instead. But now I cant seem to get the damn thing in. I can put the bit into the tranny, but then not squeeze the other end into the hub. And vice versa. But the end that goes into the tranny, when I turn it, it seems to just move around and not simply turn the tranny (sounds weird) so I just need to know if I got the right axles. Thanks!
-Rob
Old Apr 26, 2005 | 11:45 AM
Default Re: B16 in DA Axles (2manycars2choose)
Just for informations sake. I went back to NAPA and the guy brought out my core axle and we measuerd it with the one I bought (99/00 Si) and it def. wouldnt work. So we tried a 94 GSR and it was the exact fit and now its in my car. w00t!
-Rob
jayhelladum
Sep 25, 2008 09:27 AM
1bar_ek
May 18, 2008 04:44 PM
HOODLOVER
Nov 13, 2007 01:59 PM
TylerC
Nov 7, 2005 07:06 PM
