b16a2 wiring
Old Apr 27, 2005 | 05:36 AM
cbabyby's Avatar
Default b16a2 wiring
does anyone know where i can get a color coded diagram for a b16a2, by color coded i mean the colors of the wires to where they go... i just bought a b16a2 and the motor is going into my 93 civic lx and i cant finish the wiring...the company i bought the motor from cut the driver side of the engine harness off about a foot from the motor...any help would be appreciated
Old Apr 27, 2005 | 06:03 PM
NikoZai's Avatar
Default Re: b16a2 wiring (cbabyby)
An OBD0 wiring skematic for the B16 can be found on the CRX VTEC Manual. All i've got.
http://www.norcalcrx.org/library/
Old Apr 27, 2005 | 06:27 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbabyby &raquo;</TD></TR><TR><TD CLASS="quote">the company i bought the motor from cut the driver side of the engine harness off about a foot from the motor...any help would be appreciated</TD></TR></TABLE>
It doesn't matter that they cut it because whether it's a JDM harness (2nd Gen B16A) or an EK B16A2 harness. Neither would do you much good other than being able to salvage the extra needed plugs and wiring from it. You need to reuse your stock LX harness and add the VTEC solenoid, VTEC pressure switch and Knock sensor plugs and wiring. It's really not that hard at all and all the info can be found on here if you search.
goinslolsv
Apr 15, 2013 06:52 AM
cbabyby
Apr 27, 2005 05:15 AM
