stupid question, b16a engine into crx.
im new to hondas, but im lookign get ahold of a b16a engine and put it into a 90 or 91 crx si, things i would need are.
-engine
-trans
-ecu
-harness
-3 piece mount kit
-drive shafts
sounds about right?
-engine
-trans
-ecu
-harness
-3 piece mount kit
-drive shafts
sounds about right?
Re: stupid question, b16a engine into crx. (hnoppenberger)
You will also need a modified shift linkage. You will also need new radiator hoses as well. I would also suggest changing the timing belt, water pump, clutch assembly, thermostat, and any other PITA parts before your drop the B16 into the CRX.
Location: living too close to Karl, everythings busted, nc
try this link http://home.wideopenwest.com/~tschmidt/
barry11j
07-16-2004 02:59 PM
