bouncing idle...
Old May 4, 2005 | 11:16 PM
DA9teg93's Avatar
Default bouncing idle...
my idle is bouncing between about 1100 - 2000 rpm and I'm not sure what the problem really is. I thought it was the throttle cable at first, but even with careful adjusting it's still jumping like crazy... could it be spark misfiring, one of the belt fittings, a sensor not reading right, etc.? suggestions anyone??
Old May 5, 2005 | 04:54 AM
whatswawa's Avatar
Default Re: bouncing idle... (DA9teg93)
before you go replacing a bunch of sensors check the vacuum lines i made the mistake of relpacing my tps and iac before checking the vacuum lines and sure enough it wasnt the sensors but a vacuum line leak
Old May 5, 2005 | 11:37 AM
cwin's Avatar
yea it could be your tps. you can get a voltage meter to read it but i forgot what it should be set at. but it sounds like your tps. my friends hatch was doing same thing
Old May 5, 2005 | 11:54 AM
LsV91's Avatar
check the fast idle control valve if the white screw piece insde of it is loose tighten it all the way down and that might fix the problem
Old May 5, 2005 | 11:56 AM
blahhhhhhhh's Avatar
Default Re: (LsV91)
its either iacv or vaccum leak
Old May 5, 2005 | 05:49 PM
LsV91's Avatar
have you checked the fICV
Old May 8, 2005 | 05:15 PM
DA9teg93's Avatar
Default Re: (LsV91)
as a matter of fact, it was a small vacuum leak and the icv. i fixed it not too long ago and it runs just fine now. thanks for all the help!
Old May 8, 2005 | 06:48 PM
sik96teg's Avatar
Default Re: (DA9teg93)
i believe the tps settings for when its closed is .50 and im not sure about WOT mines around 4.83
Old May 8, 2005 | 07:59 PM
NVturbo's Avatar
O.G. triple O.G.
I had the same problem...found out it was the throttle body gasket. I was using a B16 gasket (LS tb...B16 manifold) and air was leaking at the bottom.
Old May 9, 2005 | 12:12 PM
YZFR6's Avatar
Check you TPS, Air Idle or vacum lines. I ran to this similar problem before. Hope this helps.
weaslehunter1
Jan 26, 2015 03:49 PM
integra15
Jun 23, 2010 02:30 PM
djviet2000
Aug 20, 2008 08:19 PM
jmcfkya
Sep 17, 2003 05:30 PM
wu tang
Jul 25, 2003 11:58 PM
