Timing belt problemes..
Old 05-04-2005, 11:05 AM
LSVtechnologytur...'s Avatar
Default Timing belt problems..
Hey guys, I have been trying to install my timing belt on my ls/vtec for a few hours now. The problem is, when i go to turn the motor back 3 teeth, the belt jumps/ slips over the intake gear. Anyone have this problem before?
btw. my set up is b18a block/crank, b16a head, itr timing belt, gsr water pump
thanks in advance
`Al
Old 05-04-2005, 06:57 PM
Default Re: Timing belt problems.. (vtec'n)
bump
Old 05-04-2005, 08:07 PM
Jmunk's Avatar
You need to use the GSR timing belt because your using the gsr water pump.
Old 05-04-2005, 09:40 PM
k00lt1nt's Avatar
Default Re: (Jmunk)
true dat....need the same timing belt as water pump u have
((((TIIITTTEEEEEEEEE))))
Old 05-05-2005, 08:22 PM
Default Re: (k00lt1nt)
I got a gsr t-belt today, and the same thing is happening. any ideas?
Old 05-06-2005, 05:57 AM
FULLTHROTTLE's Avatar
Default Re: (vtec'n)
I use the large binder clips available at an office supply store or Walgreens to hold the belt in place so you can get the rest of it on.
http://www.officedepot.com/ddM...71844
Old 05-06-2005, 06:16 PM
Default Re: (FULLTHROTTLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLTHROTTLE &raquo;</TD></TR><TR><TD CLASS="quote">I use the large binder clips available at an office supply store or Walgreens to hold the belt in place so you can get the rest of it on.
http://www.officedepot.com/ddM...71844</TD></TR></TABLE>
im not having trouble getting the belt on. the problem is when i start turning the motor 3 teeth back to adjust the tensioner, the belt starts to turn the intake cam gear, then jumps over it.
Old 05-09-2005, 01:35 PM
Which direction are you turning the motor? you shouldnt be turning it back at all, only forward.
Old 05-09-2005, 06:51 PM
antivic's Avatar
not doubting you, just wondering what would turning it the wrong way cause...i can't picture anything horrible happening
Old 05-09-2005, 07:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLTHROTTLE &raquo;</TD></TR><TR><TD CLASS="quote">Which direction are you turning the motor? you shouldnt be turning it back at all, only forward. </TD></TR></TABLE>
sorry, i didnt mean back. I'm turing it counter clockwise.
I finally got it on and tight enough for it not to jump over the intake gear, but it is still pretty loose between the water pump and intake gear.
Old 05-09-2005, 08:45 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec’n &raquo;</TD></TR><TR><TD CLASS="quote">but it is still pretty loose between the water pump and intake gear. </TD></TR></TABLE>
How loose? You can tighten the tenisor to take that slack away.
Old 05-09-2005, 10:19 PM
Supahr_Ed's Avatar
try putting the belt around:
1. crank gear
2. tensioner
3. water pump
4. EXHAUST CAM gear
5. then Intake cam gear...
maybe you can pull you tensioner up a little to tighten the slack...
rick_rabies
04-01-2009 12:59 PM
faSHOwidIT
02-25-2006 03:00 AM
B18 CYA
05-11-2005 03:11 PM
Rod.
05-30-2004 05:51 AM
infamousALLMTR
02-25-2003 07:17 PM
Quick Reply: Timing belt problemes..
