B18C sensor question?????
Old May 1, 2005 | 09:58 PM
b18c inside's Avatar
Default B18C sensor question?????
I just recently put the B18C into my 98 EK. On top of the GSR intake manifold there is a spot for a sensor. What exactly is this sensor and how do I wire it to my EK engine harness?? Please help. Thanks.
Old May 2, 2005 | 06:35 PM
Honda Sport's Avatar
pics are worth a million words...
Old May 3, 2005 | 06:08 AM
FOC-US2K's Avatar
Default Re: B18C sensor question????? (Phatcivic213)
I think you taking about the intake air temp sensor if you just extend your factor plug to reach. the other thing that would be up there is the egr purge sol. which the jdm motors didnt have.
Old May 7, 2005 | 08:44 AM
I now just need to know what to splice the sensor to on my engine harness. I got the correct plug off the other engine harness. What do i splice it to on my car's engine harness? There is an unplugged plug coming off of my fuel rail...is that it?
Old May 7, 2005 | 03:17 PM
Above6K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatcivic213 &raquo;</TD></TR><TR><TD CLASS="quote">I now just need to know what to splice the sensor to on my engine harness. I got the correct plug off the other engine harness. What do i splice it to on my car's engine harness? There is an unplugged plug coming off of my fuel rail...is that it?</TD></TR></TABLE>
What type of harness are you using?
Old May 8, 2005 | 08:46 AM
Default Re: B18C sensor question????? (Above6K)
I'm using my Civic EX harness
Old May 8, 2005 | 01:51 PM
Above6K's Avatar
Didn't your EX motor have a IAT sensor? (I have a DX) You should be able to use your existing connection.
Old May 8, 2005 | 07:50 PM
Ok call me dumb but if it had it what would it plug into on my SOHC motor? I'm not the best with wiring all the sensors up and i just wanna make sure I wire the correct ones. I have a wire that is coming off the fuel rail that isn't plugged into anything. The unplugged wire isn't one that goes with the fuel injectors...i think it is just run with them. Could that be the wire?
Old May 11, 2005 | 12:48 PM
Above6K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatcivic213 &raquo;</TD></TR><TR><TD CLASS="quote">Ok call me dumb but if it had it what would it plug into on my SOHC motor? I'm not the best with wiring all the sensors up and i just wanna make sure I wire the correct ones. I have a wire that is coming off the fuel rail that isn't plugged into anything. The unplugged wire isn't one that goes with the fuel injectors...i think it is just run with them. Could that be the wire?</TD></TR></TABLE>
Show me a pic of it.
Old May 12, 2005 | 10:59 PM
i believe i have it figure out. It is the Intake Air Temperture sensor and I've heard that i can just splice mine from my SOHC engine.
KidRuthless
Mar 19, 2014 01:07 AM
Dead CIVIC
12
Aug 30, 2010 09:27 PM
enigma94
Oct 19, 2007 10:51 PM
s2k drifter
14
May 10, 2005 04:24 PM
