engine harnes
Old May 1, 2005 | 10:44 AM
ITRnorway's Avatar
Default engine harnes
after trying to swap from odb0 to obd1. did the totaly die. so im looking for a new wiring for a p28 from the ecu and out to the engine?
so where can i buy this online? any tips?
Old May 3, 2005 | 08:22 AM
ITRnorway's Avatar
BUMP!
Old May 3, 2005 | 08:56 AM
92b16vx's Avatar
You want an OBD I, cabin harness, for a P28 ECU?
http://www.hondaautomotiveparts.com
Old May 3, 2005 | 10:42 AM
ITRnorway's Avatar
Default Re: (92b16vx)
oh, almost. engine harnes for a p28
Old May 3, 2005 | 12:17 PM
92b16vx's Avatar
So you want the engine harness for a D16Z6 that runs off a P28 ECU, right?
Go to that page and plug in the info for a 94 ex than look for harness.
Old May 9, 2005 | 05:06 AM
ITRnorway's Avatar
yeah, but im going to use the p28 on my b16. sure that the engine code is right?
my local honda dealer in norway could get the engine harnes for me, but the demanded 1300 US dollars!! there are some sick prices here
Old May 9, 2005 | 09:21 AM
92b16vx's Avatar
That's outrageous. I know the dollar isn't doing so hot, but haha that's real bad.
Yes, you want one from a D16Z6, actually, you should go ahead and get the one from a 94-95 DelSol vtec, which is the one with a B16A3, same cabin harness, but it is long enough for a B16A, and it has the right plugs. Are you guys right hand drive in Norway? Or Lefthand like the states?
Old May 10, 2005 | 10:28 AM
ITRnorway's Avatar
yeah, the dollar is real low now. we do it on the left side
tnx for the model tip. now i just need to find a place that sells them. or a wiring diagram so i can try to make one at work.
Old May 11, 2005 | 09:45 AM
ITRnorway's Avatar
Default Re: engine harnes (CRXnorway)
could it be the coil that is broken if the dizzy dont deliver a good spark and if it fails to deliver spark at the right time?
DWECKMAN83
Jan 7, 2015 08:48 AM
:::SIRll_EJ1:::
Feb 19, 2010 05:27 PM
thedao
Apr 7, 2008 09:41 PM
baphomet
Apr 12, 2004 05:48 PM
dingusjt
Jul 12, 2002 10:15 AM
