z6 swap wiing
z6 swap wiing
my Q? is, i am using the stock crx si engine harness and i just switched the plugs needed from the z6 harness right now i have everything wired up exept for the 3 plugs that are connected or are right beside the injector rez. box that wasx used by the old harness, i need to know how those are wired up so that my z6 swap will work, i have the full Z6 harness, i know i have to swap in the 8 wire grey plug with the cap on it from the z6 harness, but i have no idea waht wires go were, if someone could plz help me out. thank you.
Re: z6 swap wiing (SiRRedneck)
on the 8 pin gray plug (we've named it the "block off plug") you plug them in anywhere. 1 12v+ wire feeding the other 4 wires back to the injectors.
Re: z6 swap wiing (NikoZai)
k well i just was told by another guy that its the yel/blk and the 4 red/blk injector wires taht have to be put in the 8 wire grey plug, i realy need to know what to do, what has to be done with the wires that are not goin into the 8wire grey plug.plz help
EGbeater
11-18-2003 09:19 PM
Hatebreed215
01-17-2003 08:26 PM
I Gotta Question
01-02-2003 03:51 PM
