Question about N1 crank pulley and alternator belt
alright im asking for 2 different cars here, the first is my car which has a b20 with b16 head and i need to know the part # for the alternator belt i need to use with the n1 crank pulley and the second car that i need the alternator belt infor for the n1 is a b16 a2. any help is much appreciated, i have looked and found like 3 different part numbers and each seem to vary depending on the block, i was told 4pk745 for b20 and 4pk735 for b18 but couldnt find b16. if anybody knows i could really use the help.
Re: Question about N1 crank pulley and alternator belt (fkncivic)
I can't remeber that part # I used, but I do know it is a Acura Vigor 92' power steering belt, 4 rib. That should work on either one of the applications.
it really depends on the car..i have a B20 w/ obd1 gsr alternator...the vigor PS belt did not work... 31" ,30", 29", 30.5" all doesnt work for me...
i have not tired a 29.2" or 30" wit washers on the alt. bracket yet..but the part number you have are 4pk745 or 4pk735, the last digits are the mm length....if one doesnt fit, just get the next size up. i heard most people use 735mm but that did not work for me...
Re: Question about N1 crank pulley and alternator belt (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">295k4 belt will work fine </TD></TR></TABLE>
what car is that off of?
Re: Question about N1 crank pulley and alternator belt (Autoworks)
ok thanks for the b16 info, but does anyone know which on will work for a b20?
295 k4 will work fine on the b20, i have used this on a b18 and a b16a with zero problems
vladd
12-06-2006 07:18 PM
BoostinEJ1
12
05-09-2006 06:52 PM
