What mounts for B-series in EK
Re: What mounts for B-series in EK (dc2drifterx)
i know for sure you use the 99-00 EM1 rear tranny bracket
as far as drivers side i think the d series will work? someone please correct me, i would also like to know.
and also can you use the d series post for b series?
All you would need is the 99-00 si rear mount and bracket. You can use the regular dx driver side mount but i suggest to upgrade it because it will be the first mount that will go out on you. I would suggest get the place racing driver side mount or better get the hasport mount kit
Re: What mounts for B-series in EK (JdmLub)
u can us the stock mounts but u need the rear triangle mount and the hard block mount from a a 99-00 Si, I would suggest getting a set of hasport mounts since the stock mounts are a little soft.....
Re: What mounts for B-series in EK (SkRiBLaH)
if u are gonna swap a b series in a EK u need either a gsr, or SI rear mount, and u can use your sohc mounts on the side and i would use the integra ones that mount to the front of the block and the front of the tranny !
Re: What mounts for B-series in EK (rw92civic)
this is what you need i'm 100% sure.
99-00 Si Rear Tranny Mount bracket: 50827-s04-n10
99-00 Si Driver Side mount bracket: 11910-p30-000
#7 & (the other part is not numbered on this picture .. but it's right next to e14-1)
oh yeah
if you're going to keep AC, you need this
96 del Sol VTEC AC bracket: 38930-P54-000
#1 in the picture
oh yeah
#1 in the picture
Re: What mounts for B-series in EK (BlueIntegraBoy)
yeah u can't use a integra rear mount, only the 99-00 Si, and the block mount i was talking about is the cast peice bolted to the driver side of the motor that has the stud's in it
all you had to do was search. i did a write up a while back on swaps.
https://honda-tech.com/zerothread?id=983454
Re: (Ej6B20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6B20 »</TD></TR><TR><TD CLASS="quote">what about the front tranny bracket? I thought you had to use the one your tranny is from</TD></TR></TABLE>
nope you use the one for the B series tranny.
We have a 5 piece mount kit that drops your motor right in. It replaces the driver side mount too with a much stronger one. All Billet Aluminum.
SyDuck
01-28-2005 06:59 PM
