golden eagle ls/vtec conversion kit question.....
Old Apr 21, 2005 | 02:14 PM
ReV LiMiT's Avatar
Default golden eagle ls/vtec conversion kit question.....
i just bought the ls/vtec conversion kit off ebay and it came with a stock brand new gsr head gasket..... i thought when you do ls/vtec, your supposed to use an ls head gasket. correct me if im wrong with the ge kit...
thanks
Old Apr 26, 2005 | 01:46 PM
ReV LiMiT's Avatar
Default Re: golden eagle ls/vtec conversion kit question..... (9d DA6 TEG)
bump....
Old Apr 27, 2005 | 07:02 AM
dohcdelsol93's Avatar
I just installed my ge kit. The h.gasket that comes with the kit looks weird but it works. It is supposed to be a stock ls gasket if your not using the the ge kit. https://honda-tech.com/zerothread?id=1161948 here's a link with some pics
Modified by dohcdelsol93 at 8:31 AM 4/27/2005
Old Apr 27, 2005 | 07:21 AM
X-Mazda 3 Racer's Avatar
Default Re: golden eagle ls/vtec conversion kit question..... (dohcdelsol93)
We use the GSR gasket in our kits because we have found them to work excellent.
Old Apr 27, 2005 | 07:31 AM
Default Re: golden eagle ls/vtec conversion kit question..... (GoldenEagleMfg.com)
GE rocks, i'm using their ls/vtec conversion kit, arp head studs, and sandwitch plate for my turbo and vtec oil feed.
Old Apr 27, 2005 | 07:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">GE rocks, i'm using their ls/vtec conversion kit, arp head studs, and sandwitch plate for my turbo and vtec oil feed.</TD></TR></TABLE>
Thanks for the good words.
Old Apr 27, 2005 | 08:03 AM
I forgot to mention i'm using your rods too.
Old Apr 27, 2005 | 08:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to mention i'm using your rods too. </TD></TR></TABLE>
We don't make rods. We get that all the time. Eagle Specialty Products ( rods and cranks ) is a completely different company that Golden Eagle Mfg. Don't worry, you are not the first, and won't be the last, to confuse the two companies No worries
Old Apr 27, 2005 | 09:35 AM
ha...shows what I know. I guess that ruins my credibility on recomending your parts.
Old Apr 27, 2005 | 09:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">ha...shows what I know. I guess that ruins my credibility on recomending your parts.</TD></TR></TABLE>
No worries, if it says Golden Eagle and you like it and recommend it, then you are o.k. in my book
Old Apr 27, 2005 | 02:09 PM
ReV LiMiT's Avatar
thanks alot. so the only thing i would have to do is tap the head and just bolt it on like i was doing a normal head swap?
Old Apr 27, 2005 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9d DA6 TEG &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot. so the only thing i would have to do is tap the head and just bolt it on like i was doing a normal head swap?</TD></TR></TABLE>
Pretty much
Old Apr 27, 2005 | 06:49 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">
No worries, if it says Golden Eagle and you like it and recommend it, then you are o.k. in my book</TD></TR></TABLE>
Not sure about your full conversion kit, but I do know that your dowel pins really help out the procedure. to GE dowel pins!
Old Apr 29, 2005 | 01:11 PM
92_civic's Avatar
Default Re: golden eagle ls/vtec conversion kit question..... (VTECVillain)
a little off topic, but... does it matter witch head gasket you use? I have always heard LS
Old Apr 29, 2005 | 01:18 PM
Default Re: golden eagle ls/vtec conversion kit question..... (92_civic)
Everyone who put together their own conversion kit says to use the ls but with the research that Ge has put in their kit (and the liability they face if they screw up) if they say the gsr works great I'm sure it does. I'm using the GE kit and mine fit fine. The dowel pins they provided really helped out
eh2_erik
Nov 5, 2013 11:25 AM
bowdown201
Nov 11, 2008 01:44 PM
mcyang87
Dec 29, 2007 12:04 PM
Daniel-sanB1
Mar 16, 2007 05:35 PM
