ls/vtec timing belt
ls/vtec timing belt
i have searched and really didnt come up with much. did find a b20vtec thread. i kind of got an idea of what i can use but i wasnt sure. if i use an LS water pump then i use the LS timing belt and if i use a vtec water pump then i use a GSR timing belt correct? TIA
Re: ls/vtec timing belt (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 »</TD></TR><TR><TD CLASS="quote"> if i use an LS water pump then i use the LS timing belt and if i use a vtec water pump then i use a GSR timing belt correct? TIA </TD></TR></TABLE>
You are right sir.
Glenn
You are right sir.
Glenn
for future reference (not being a smart *** here) I can never find anything for the ls/vtec in archives when i search ls/vtec, try using ls vtec.
Re: (2highPsi)
yes use the 22tooth gsr w.p. Much better coolant flow than the 19 tooth ls. Also consider using the gsr oil pump. It is also superior to the ls.
turbo_b16_ex
10-04-2005 11:06 AM
wade
06-20-2004 02:21 PM
