D series AC compressor on B series engine?
Old 05-04-2005, 08:06 PM
Mentat Ghola's Avatar
Default D series AC compressor on B series engine?
Can i keep the factory EG d series AC system and bolt up the compressor and reuse the belt if i install a b16 and use a del sol AC breacket? And does a del sol AC bracket bolt up to a JDM b16a2?
Old 05-05-2005, 05:36 AM
dwnthehatch's Avatar
Default Re: D series AC compressor on B series engine? (Mentat Ghola)
Yes and yes (as long as it is a DOHC VTEC del sol AC bracket).
Old 05-06-2005, 05:04 AM
zz10xx's Avatar
anyone know if the d series ps pump can be reuse to?
Old 05-06-2005, 05:10 AM
92b16vx's Avatar
P54 from the 96-97 DelSol vtec is the right one. The P30 does not accept a Civic D series compressor.
And some people have used the CRV bracket, but I don't know the number of hand.
Old 05-06-2005, 11:48 AM
Default Re: (92b16vx)
ok im geting mixed answers here. Yes or NO?
Old 05-06-2005, 11:55 AM
92b16vx's Avatar
Default Re: (Mentat Ghola)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola &raquo;</TD></TR><TR><TD CLASS="quote">ok im geting mixed answers here. Yes or NO?</TD></TR></TABLE>
Not really, yes you can use the Delsol bracket, just has to be the right one.
How do I know the P30 won't work you ask?... http://www.hondaswap.com/forum...4&hl=
Old 05-07-2005, 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">P54 from the 96-97 DelSol vtec is the right one. The P30 does not accept a Civic D series compressor.
And some people have used the CRV bracket, but I don't know the number of hand.</TD></TR></TABLE>
The crv bracket will work unless you swap a b16 motor in. If you swap a B16 in the crv bracket will not allow you to mount the ps bracket since the b16 head is not as tall as the b18. With a B18 you will have no problems with the crv bracket and keeping your ac.
The crv bracket's part # is 38930-P7J-000 and it costs about half of what a delsol vtec bracket.
Old 05-07-2005, 06:14 PM
xEnderx's Avatar
Default Re: (dwnthehatch)
Yeah, with a Del Sol Vtec AC bracket you can retain your stock AC compressor. Not sure on teh PS pump, but I DO have a Civic Type R PS pump that I can sell you for 25 bux plus shipping if you want to try that. I don't really see the point of having PS in a car as light as a civic.
Old 05-07-2005, 09:31 PM
Default Re: (xEnderx)
no power steering required.
Old 05-14-2005, 05:48 AM
zz10xx's Avatar
any1 have a more direct answer regarding D series ps/ac pump on a b series? using b series bracket.
camoxiong
08-14-2014 01:51 PM
JDMCRX
06-18-2009 05:11 PM
Speed94
08-13-2008 03:32 PM
crazyguy
12
06-10-2007 01:45 PM
slowpokesi
17
07-20-2002 08:31 AM
Quick Reply: D series AC compressor on B series engine?
