motor swap
motor swap
My friend is about to drop a 94 h22a1 with a manual transmission into a 97 accord lx with a automatic transmission, He only could find a 93 accord manual transmission would it fit or would he need a transmission from the same year as his car? He also wanted to know if there was any aftermarket motor mounts that comes in a set.
Re: motor swap (majek)
The trans will bolt up fine but the only thing I'm unsure of is the passenger side trans mount I'm not sure of the years that have the smaller bolt pattern so I would just see if the 97 accord mount bolts to the trans if so then its A direct bolt in, that is the only differences.
BoostedH23Accord
12-04-2008 05:30 AM
viciousvisionslarry
01-18-2006 02:51 PM
