B16a2 into crx
B16a2 into crx
my buddy wants me to put a b16a2 into his 90 crx it has a d series motor. I know its pretty much a direct bolt on, but wheres a good place to get OBD conversion harness' and is there anything i should know or do. thanks if anyone knows it be you guys.
Re: B16a2 into crx (Rudelude22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rudelude22 »</TD></TR><TR><TD CLASS="quote">my buddy wants me to put a b16a2 into his 90 crx it has a d series motor. I know its pretty much a direct bolt on, but wheres a good place to get OBD conversion harness' and is there anything i should know or do. thanks if anyone knows it be you guys. </TD></TR></TABLE>
Just thinking about the basics, you will need a B-series mount kit, either a cable tranny or a cable to hydro conversion kit, 90-93 Integra axles, a modified shift linkage, and all the usual stuff like belts, hoses, fluids, sparkplugs, thermostat, etc. As for the OBD conversion harness, check out either rywire.com or boomslang, both are vendors here on H-T.
Re: B16a2 into crx (GreyDel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel »</TD></TR><TR><TD CLASS="quote">Don't forget to find a OBD0 Dizzy for a B-series....if you can</TD></TR></TABLE>
If you're going to be converting don't do this.
6doorsentra
08-28-2006 02:00 PM
