Dizzy Question!!!!!!!!!!!!!!!!!!!!!
Old Jul 29, 2005 | 09:17 AM
civicexstacy's Avatar
Default Dizzy Question!!!!!!!!!!!!!!!!!!!!!
Ok, I've searched this forum high and low to no avail.
Here's the deal, The '00 EX has an 8pin single harness and the '95 SiRII Dizzy has 2 plugs (one 7pin, one 2pin). The EX harness fits into the 7pin plug on the dizzy and I routed the one Blk/Yellow wire from the EX harness to the 2pin SiRII harness. However, I can't figure out what the Dark Blue wire comming from the SiRII 2pin plug is for and there isn't a left over wire to hook it up to. I looked at a '99 SI Dizzy plug and it looks like this wire is a delete. I'm stumped. Please help. BTW I have all the other wires matched up as per a schematic that I was given. I don't have the $ to buy an OBD2 SI dizzy and I already have the OBD2b to OBD1 jumper. Thanks in advance for your help.
Josh
Wiring OBD1 (in order left to right, top to bottom 7-pin plug off dizzy)
1. Yellow/Green
2. Blue/Green
3. Orange/Blue
4. Orange
5. Factory Delete (no wire)
6. Blue/Yellow
7. White/Blue
8. White
2pin plug
1. Dark Blue (what does this go to? This is where I'm lost)
2. Black/Yellow
Wiring OBD2 (in order L to R, T to B 8-pin plug off main harness)
1. Yellow/Green
2. Dark Blue
3. Green
4. Yellow
5. Black/Yellow (cut and spliced to Black/Yellow from 2-pin plug)
6. White
7. Red
8. Black
All numbers match on OBD1 and OBD2 harnesses (except 2-pin). Hope that helps
Old Jul 30, 2005 | 09:07 AM
Default Re: Dizzy Question!!!!!!!!!!!!!!!!!!!!! (civicexstacy)
BUMP
Old Jul 31, 2005 | 10:29 AM
bump for help please
Old Jul 31, 2005 | 06:35 PM
locash's Avatar
The dark blue wire is the tach signal. The 99-00 Si does not need it, as the cluster gets its tach signal directly from the ecu.
f20bcl
Jul 23, 2010 07:55 AM
TurboGoKart
20
Apr 10, 2007 11:51 AM
DEL HATCH
Aug 29, 2006 06:23 AM
Kwuaymaikrup
Jan 27, 2005 10:34 PM
