which loom and ecu for h22?
ok guys a local scrappy have a h22 prelude in and the engine and loom+ecu is a good price (very good infact)
now my car is a b16a2 delsol, should i just use its existing loom+add resistor box or use the whole h22 loom+ecu (im guessing it will save me cutting the crap out of my delsol one)
iv looked at the big stickey at the top of the page and it seems there is a fair bit of work swapping wires around on my existing harness.
any ideas to fitting the h22 loom+ecu or any forseable problems fitting that ecu?
all i need now is one of those H2B adaptor kits :D
cheers
cheers
Re: which loom and ecu for h22? (Aaran)
it is much easier to just add the wires you need and to make the wires longer where u need to. So modify your existing harness.
Re: which loom and ecu for h22? (MrMike)
Rywire.com - we can rebuild your Del Sol engine harness for the H22.
We need both engine harnesses and it would be VERY good if the Alternator wire isn't cut on the H22 harness, because we re-use those for their length and you can't solder 4-10 Gauge wire.
We can do it for $180. Refer to this post when contacting us, phone # is on the website.
(And I rarely check PM's on here so email or call please)
http://www.rywire.com - I'm Peter at rywire.
http://www.quartersportsdrag.com - Seth rocks. Get that H2B adapter kit!!!
OneMadAccord
11-04-2009 08:19 AM
STEV3-O
03-05-2008 04:37 PM
