vtec solinoid
Old Jul 25, 2005 | 11:38 PM
crx90rcr's Avatar
Default vtec solinoid
when u turn ur car to the pre ignition setting with the key were your fuel pump is sapposed to prime is your vtec solinoid sapposed to click
Old Jul 26, 2005 | 02:26 PM
crx90rcr's Avatar
Default Re: vtec solinoid (crx90rcr)
bump
Old Jul 26, 2005 | 07:41 PM
Hapexamendios's Avatar
i dont think so
Old Jul 26, 2005 | 10:29 PM
crx90rcr's Avatar
Default Re: vtec solinoid (Hapexamendios)
any one kno 4 sure
Old Jul 27, 2005 | 05:27 AM
IHateJDM's Avatar
no, but you can put the solenoid's wire on a power source and it will click.
Old Jul 27, 2005 | 10:50 PM
NikoZai's Avatar
Default Re: vtec solinoid (IHateJDM)
NO
Fix:
1. Get a volt meter.
2. Set it to check "Continuity" (read the manual that came with the volt meter)
3. One volt meter lead on VTEC solenoid wire.
4. Unplug ECU
5. Other volt meter lead at ECU, checking for where that wire is. (should be at A8 if OBD0)
(if the volt meter has an audible setting, it will beep at you when you touch the other end of that wire.)
If that pin is not at A8 which i suspect it's not. You need to move it to A8
You're welcome.
Old Jul 31, 2005 | 08:28 AM
crx90rcr's Avatar
Default Re: vtec solinoid (NikoZai)
i used a hasport wireing sub harness so it should b were it needs to b
Old Jul 31, 2005 | 08:33 AM
curioso's Avatar
check ur wiring it should be in a8 like they said before
kornkid21792
Feb 10, 2010 06:48 PM
lsvtecSIrex
Jun 14, 2006 03:13 PM
ilovemyb16a
May 18, 2006 12:58 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
Ibuprofen
Sep 3, 2001 08:15 PM
