b16 not running up to par
i have a b16 in my 90 crx si and have been having problems since i got the engine swapped in i did all the maintenace stuff plugs wires, cap rotr, water pump tbelt, tensioner. checked timing marks on cams 3 times and they're good, checked and adjusted distributor timin and got it running a lot better, i replaced the o'2s with one known working one, and a oem replacemnt,
i get cel's for both o'2s before and after i changed them, so i higly doubt its 4 bad o'2s... ive tried switching the o2's around to no avail... ive alswo replaced iacv with known working one
cold start engine stumbles right off idle till like 2k then gets better when it warms up, used to shut right off when it would start up cold, i had to keep it running , but when warm it wouldnt, thats why i replaced iacv, problem got better but is starting to come back. cleaned vtec solenoid also. no dashpot valve
engine pulls from 2k -4k ok, then you can feel it bog at part throttle, and doesnt get better till 7k where it pulls hard
im running pr3 ecu with everything stock. please help ive searched a whole lot and no one has had similar problems,
Re: b16 not running up to par (work-in-progrex)
Have you had it propperly timed (by the distributer with a timing light)? Also you might try getting a new fuel pump. I noticed that mine ran a tiny bit better after I replaced the pump. You might want to find someone that backs me up on this though...
Re: b16 not running up to par (sitinthehall)
yes, i timed it with a light... i also think it could be the fuel pump , because it seems like its getting worse, i just ordered a fpr and gauge so... hopefully that will give me an idea of whats goin on...when im on the highway i can feel it not really hesistating, but something close to that but if you get on the gas it goes away, also when i got into town it seemed like it was boggin a bit more than usual... i think im going to have to order a new pump
Alex_C
10-07-2008 09:45 PM
RenoRacing
04-07-2003 06:16 PM
