compresion ?
Old Jul 23, 2005 | 08:33 AM
grncivic98's Avatar
Default compresion ?
i have a 98 civic that i put a 99 b18c1 obd2 into this winter, and the other day it got a loud clatter sound on the driver side of the moter, i ran a compresion test and i have about 150 to 160 on the first 3 cylinders and on the fourth on i only have about 100 to 105. i'm looking for any ideas that this might be.
Old Jul 23, 2005 | 07:11 PM
SixguN's Avatar
Default Re: compresion ? (grncivic98)
If I were you, I would pull the head. Especially with that compression. Check your valves. IMO, It sounds like the your valves had some contact. Hope fully they are just bent and didn't break off and do damage to the piston, if this is it.
Old Jul 24, 2005 | 08:48 AM
grncivic98's Avatar
Default Re: compresion ? (Sixgundone)
what do you think about a lifter problem
Old Jul 24, 2005 | 09:18 AM
PURPLETERROR aka BIGMATT's Avatar
Sounds like bent valves, Your motor does not have lifters, you have lma's and they wont cause a loss in compression.
b18-crx
Apr 22, 2009 08:16 AM
zccrx
Nov 12, 2008 07:26 AM
leeminho86
May 18, 2006 08:14 AM
Baron55
Dec 24, 2005 08:02 AM
slowazzhatch
13
Jun 1, 2004 08:51 AM
