Need help, need pictures of Hasport mounts
Old 08-03-2005, 07:10 PM
H22 EH!'s Avatar
Default Need help, need pictures of Hasport mounts
I need pictures or instructions on installing Hasport's EGH2 mount kit for an H22A into a 92 civic hatch. More specifically, I'm having difficulty with the passenger side mount and bracket. Any info your have would be appreciated. Pictures of installation or finished installation would be Awesome.
Old 08-04-2005, 04:48 PM
93preludeh22's Avatar
someone post this!
Old 08-05-2005, 06:05 PM
gogogogogogo
Old 08-14-2005, 01:39 PM
Default Re: (93preludeh22)
Passenger side tranny mount removal... ANYONE?!?!
Old 08-14-2005, 03:50 PM
HavokB18's Avatar
calm down and ill go take pics in a minute? You dont know how to get the bracket off?
Old 08-14-2005, 03:56 PM
HavokB18's Avatar
nm its raining youll have to wait till it stops or hit me up on aim. irhavok
Old 08-14-2005, 04:59 PM
KingJeff's Avatar
Default Re: (HavokB18)
it's raining in OK? It's hot as **** here in Sacramento. IT's over 100.
Old 08-14-2005, 05:07 PM
Default Re: (KingJeff)
I know what the mount looks like.. this will be my second h22eg hatchling..
I just need to know how to remove the bracket from the frame rail.
The install was done professionally last time. I paid too much and want to do it myself.
The instructions say either die grind it or drill the spot welds... Which method is preferred?
I would rather drill the welds.... I don't know.
Pictures if anyone has please!!
Thanks
Old 08-14-2005, 05:38 PM
HavokB18's Avatar
i used a prybar and a large hammer... then i used chisles and a hammer to clean it up some. that was on my swap... I used a grinder on my friends swap it was easier in some cases and harder in others... Its no science just get it off of there
Old 08-15-2005, 09:47 AM
MrMike's Avatar
drilling is the easiest i think. drill out the stop welds, u can see them, they are the dimples in the bracket, but don't drill all the way through the frame rail. after that wack it with a really big hammer and pry it off with pry bar, and grind it smooth with a grinder.
Old 08-15-2005, 06:17 PM
Thanks MrMike!
Old 08-15-2005, 06:54 PM
MrMike's Avatar
we usually like to spray paint that area where the bracket used to be a similar color to the car color so it doesn't look to obvious that its been removed aswell. we also do that when we weld in 5speed brackets after removing the auto brackets cuz the brackets come black from the dealer.
Old 08-19-2005, 10:18 AM
HavokB18's Avatar
here ya go
kulo
05-17-2013 04:32 PM
Hatch_Kid
13
12-31-2012 06:22 AM
b20vtechatch
04-10-2005 11:46 AM
Sir_Phobos
11
04-10-2003 09:13 PM
mraudio13
02-13-2003 05:27 AM
Quick Reply: Need help, need pictures of Hasport mounts
