H22 vs B18
Old Aug 8, 2005 | 05:51 PM
hondapwred95's Avatar
Default H22 vs B18
i have a 95 civic hatch and would like to do a motor swap next year, new to swaps but want to know if i should go with a h22 or b18, favoring the h22 because it has more hp and torque, this is going to be a dual purpose car with the everday streets but also a weekend racer give me tips. give me any suggestions thanks mike ( looking for the best bang for the buck want to stay under 3000 for the complete swap ) Help
Old Aug 8, 2005 | 06:21 PM
NXLude's Avatar
This forum is chalked full of info.....
1. Search
2. Read
3. Ask questions
Old Aug 8, 2005 | 07:33 PM
Vtecme92's Avatar
Default Re: H22 vs B18 (hondapwred95)
If you are talking 1/4 mile time they are about the same- depends on the driver..but if you are taking about on the highway I'll take the h22..
Old Aug 9, 2005 | 01:08 AM
94_HATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwred95 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 civic hatch and would like to do a motor swap next year, new to swaps but want to know if i should go with a h22 or b18, favoring the h22 because it has more hp and torque, this is going to be a dual purpose car with the everday streets but also a weekend racer give me tips. give me any suggestions thanks mike ( looking for the best bang for the buck want to stay under 3000 for the complete swap ) Help</TD></TR></TABLE>
If your gonna do this swap next year you have plenty of time to search for that answer. But ill give you a hint...its a sticky
Old Aug 9, 2005 | 09:30 AM
. o 69 o .'s Avatar
Default Re: H22 vs B18 (Vtecme92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecme92 &raquo;</TD></TR><TR><TD CLASS="quote">If you are talking 1/4 mile time they are about the same- </TD></TR></TABLE>
Most guys with stock h22 swaps are running high 13's on street tires (myself included) I have never seen a stock b18a,b,c run a 13's pass... possibly a c5, but definitely none of the others...
h22 all the way
Old Aug 9, 2005 | 01:47 PM
C M S's Avatar
Default Re: H22 vs B18 (B16B)
H22 . But u cant go wrong either way!
Old Aug 9, 2005 | 01:57 PM
Pikachu's Avatar
Build it and Boost it! It'll be more fun that way...
Old Aug 9, 2005 | 05:52 PM
Default Re: (Pikachu)
thanks for all your help can anyone that has done a swap to a eg tell me how hard it it as i said before this is my first swap but i really want to do itif anyone is in the ohio area let me know want to see what it looks like and how it performs(H22)
Old Aug 9, 2005 | 06:44 PM
Pikachu's Avatar
The sticky really tells you all you need to do. It's quite good so just use that.
Old Aug 9, 2005 | 07:15 PM
ya i saw that, show what are the pros and cons h22 owner? was it worth it let me know personal take on the swap
Old Aug 9, 2005 | 08:50 PM
lakerschamp2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecme92 &raquo;</TD></TR><TR><TD CLASS="quote">If you are talking 1/4 mile time they are about the same- depends on the driver..but if you are taking about on the highway I'll take the h22..</TD></TR></TABLE>
do your homework
h22 type S vs b18 R
h22 vs b18c
in both cases, the h22 would walk away the b18 with ease.
if you were to compared them, take the best vs best, don't just compare regular h22 to b18r, it's not relevant.
Old Aug 10, 2005 | 10:00 AM
Pikachu's Avatar
Default Re: (hondapwred95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwred95 &raquo;</TD></TR><TR><TD CLASS="quote">ya i saw that, show what are the pros and cons h22 owner? was it worth it let me know personal take on the swap</TD></TR></TABLE>
It definately takes a bit of cash to do all this. It's not a simple swap nor cheap. But the rewards are pretty good. Having an H22 in your car has the unique feel to it. The power is definately there and the torque is just fantastic. If you can get all that to the ground, you can run low 13's to high 12's at the track all day. That's stock. Build it up and it gets more fun. I'll post some pics of my car as well as dyno sheets when I'm completely done in the next few days.
The biggest issue with this swap is wiring and axles IMO. The wiring is just easier now with all these conversion harnesses and what not. Axles... You will break them... For me, it's always the passenger side axle that breaks. Other than that, a stock motor is reliable as a daily as I have a friend of mine that drives his H22 Civic everyday to work. Gas mileage isn't as good of course.
Old Aug 10, 2005 | 10:54 AM
Specail Ed's Avatar
I've owned both, so here's my side. '92 Hatch with '95 B18C1 = 14.7@97 1/4 mile time. '92 Hatch with '95 H22 = 13.8@101 1/4 mile time. Both on street tires, only mod was exhaust.
Pros for the H22: Tons of torque, great midrange power, doesn't need lots of revs to get moving.
Cons for the H22: I've gone through three passenger side axels in two years, expensive to swap, vibration with HASport mounts, fitment issues.
Pros for the B18: Easy swap very straight forward, tons of available parts, a cheaper swap by comparison to the H22.
Cons for the B18: Need to keep the revs up to get moving, the swaps can be overpriced if you don't shop around.
Here's my verdict. If this is your first swap, start with the B18. They are a direct bolt in with the only real modifications coming to the wiring. My B18 Hatch was my first swapped car. I loved it, drove the crap out of it, and still averaged about 40 miles per gallon. My H22 Hatch was my second swapped car. This was the second H swap I had done so I was familiar with what all it needed. Don't be fooled by price for price on the motors. The H is cheaper, but odds are you'll need unforseen items like axles, shift linkage, a shifter box, injector resistor, mounts, a center shaft, and so on. I'd say I had about $3000 into my B swap and until everything was said and done about $4500 into the H (JDM motors need some other mods ie. fuel line and complete change of the wiring harness.) With the money you'll save by doing the B swap you'll be able to sink that money back into the motor for future improvements. It's completely up to you, but that's my two pennies.
Old Aug 10, 2005 | 02:48 PM
What kinda aftermarket axles do you recommend if any, what kinda gas mileage do you get in the hatch under normal driving
Old Aug 10, 2005 | 02:54 PM
Specail Ed's Avatar
The best thing to do for axles is to just get reman ones from AutoZone or Advanced Auto. They have a lifetime warranty and you can take them back at anytime. If you're like most of us, find some trashed axles and stock pile. For 60 bucks, you really can't beat the deal, plus lifetime warranty.
Old Aug 10, 2005 | 03:52 PM
User 5426's Avatar
Default Re: (Specail Ed)
I guess that I am very luckey with my axles. I've never had any problems with my passenger-side. I had serious binding problems with my driverside though. Binding and it broke. Replaced with one dss axle and never had any binding of breakage for almost 2 years now.
Gas mileage is also great. That motor was meant for a prelude so dropping it into an eh2 will give it great mileage.
Disclaimer: Mileage claims are based on "Old Lady Driving without hitting Vtec" . It takes a lot more gas when you drive it hard all the time, but still not too bad.
Old Aug 10, 2005 | 04:33 PM
Default Re: (SeaQuake)
so what kind of mileage can i expect if i drive it at like 4000 rpms or normal driving
Old Aug 10, 2005 | 04:34 PM
anyone got pics or video of there h22 in action?
Old Aug 10, 2005 | 06:29 PM
turboelementshane's Avatar
K20 SON,THAT WELL BEAT A H22. H22 IS OLD
Old Aug 10, 2005 | 06:38 PM
NXLude's Avatar
^^^and the same power for 1/3 the price
Old Aug 20, 2005 | 06:25 AM
Default Re: (bdazzteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdazzteg &raquo;</TD></TR><TR><TD CLASS="quote">K20 SON,THAT WELL BEAT A H22. H22 IS OLD</TD></TR></TABLE>
not quite, if a k20 type s vs h22 type s, the h22 would walk away the k20.
Old Aug 21, 2005 | 11:27 PM
pimprascalzh22a's Avatar
hey i did the swap about 9 months ago its fairly easy once you got everything organized without missing any parts. took me and two other people about 3 hours to complete the swap. dont go b18! my stock JDM h22a in my civic coupe full interior with system NOT a hatchback smoked a semi-built b18 c5 in a fully gutted hatchback by 3 cars! No lie!
Old Aug 22, 2005 | 09:08 AM
fastwanabe's Avatar
Default Re: (pimprascalzh22a)
I've had my H swap for about three years and only broke an axle once, driver side broke. The problem is that most people use the 90+ integra axle when in reality you need 88-89 axles. The 90's are too long by about 1 1/2 inches. Ever since I used the 89's I get no binding and no vibrations.
Old Aug 22, 2005 | 09:25 AM
RotiEatter's Avatar
Ditto
Default Re: (fastwanabe)
I'm running Gator Racing Stage 2 axles, haven't had many problems really.
I don't mind the HASport mounts at all. My car vibrates, but my suspension is stiff anyways. I don't really care anyhow, I love how it handles.
Umm, I get about 30mpg with my H22... crusini' at 87mph is about 4000rpm in 5th gear sfor me. So you get pretty good gas mileage. I usually shift around 2100-2500 around town.
Old Aug 28, 2005 | 08:42 AM
01integra-typer's Avatar
same power,more touqe, less money
