LS Block Help
Old Aug 7, 2005 | 10:16 PM
testingcheck's Avatar
Default LS Block Help
I did a search and couldnt find the right answer to this.
I know the main problem for a LS/VTEC build is the rods are weak to handle high-reving so replacing them with stronger rods (Eagle Rods) will help this, but is that the only problem?
Also what other things should I change inorder for this engine to be reliable and be able to handle high reving?
Old Aug 8, 2005 | 01:28 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: LS Block Help (testingcheck)
Ls rods are fine, its the rod bolts and rod bearings that are weak. Upgrade to arp rodbolts, and b16a rodbearings, and a vtec oil pump and you will be fine.
Old Aug 8, 2005 | 07:24 PM
I got VTEC water pump, VTEC oil pump, and VTEC Timing belt. So replacing stock rodbolts with ARp bolts will make it run more reliable and be able to handle high revving. Is there anything else?
Old Aug 10, 2005 | 09:49 AM
addmotorsportskimball's Avatar
Default Re: (testingcheck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by testingcheck &raquo;</TD></TR><TR><TD CLASS="quote">I got VTEC water pump, VTEC oil pump, and VTEC Timing belt. So replacing stock rodbolts with ARp bolts will make it run more reliable and be able to handle high revving. Is there anything else?</TD></TR></TABLE>
very important that u have a vtec oil pump... many people forget to use on... my friends ls/vtec has the ugliest bearing due to lack of oil under high rpm's.... and the crank heated up so much it turned blue.... now thats hot!!!!!
Old Aug 14, 2005 | 10:50 AM
I was also wondering. I was also old I need new main bearings but which brand is good to use?
The Si
11
Feb 13, 2007 01:34 PM
Boosted_Coupe
Mar 17, 2006 05:12 AM
hondaguyexsi
Oct 12, 2005 05:19 PM
Speed_Dreams
Jul 27, 2003 01:48 PM
paulzy
Jun 27, 2001 11:06 AM
