help with cel--b18c1 in eg
Old Jul 21, 2005 | 09:48 AM
93si-hybrid's Avatar
Default help with cel--b18c1 in eg
Hi i have a 93 si hatch with a 94 gsr swap. I have a cel when the car is running,when i jump the wire there is no cel. I'm using a p72.
I just wired up the iab, and just put in my o2. I had it running fine with the knock sensor wired and no iab or o2 in. Any help would be great. Thanks.
I fixed the 3500 rec limit problem.
Modified by 93si-hybrid at 7:53 AM 7/22/2005
Old Jul 21, 2005 | 11:23 AM
StErN's Avatar
Default Re: help with cel--b18c1 in eg (93si-hybrid)
Are you using the SI harness? Are you sure that you wired all the wires into the correct pins? Because if not the sensors could be through the ecu off. IAB=yellow/black-->yellow/black or A25 which is a 12v power source, pink/blue wire-->A17. Also what codes are you throwing with the way things are setup now?
Old Jul 21, 2005 | 12:19 PM
yes everything wired correct. i'm not getting any codes so it might be my ecu.
Show15
Aug 7, 2011 07:14 AM
do_0b
Apr 2, 2008 03:19 PM
da9blk1
21
Mar 16, 2008 09:18 PM
jay-d-em
19
Jul 20, 2007 05:07 PM
nub_pwn
11
Nov 19, 2006 02:32 PM
