Need info on 94 integra ls motor swap into my 93 delsol
Hi! I found a guy parting out his 94 integra ls .. I have a 93 delsol. i am new to this .. don't really know much. Need to know what i would need for this swap. Any information would be very much appreciated. Thank You.
Re: Need info on 94 integra ls motor swap into my 93 delsol (newbiedelsol)
Basically you'll need everything from the 94 LS minus the shiftlinkage (everything mean all the motor mounts, wiring harness, upper & lower radiator hoses, ECU). For the shiftlinkage, you'll need to get a 94+ Del Sol DOHC Vtec shiftlinkage. If you want to keep AC, then you'll also need P54 A/C braket from the DOHC Vtec Del Sol. For P/S, get all the upper and lower bracket including the pump from the LS swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newbiedelsol »</TD></TR><TR><TD CLASS="quote">what abt axles? </TD></TR></TABLE>
You need to get the engine, trans, ecu, all motor mounts, rear tranny bracket, axles , and shiftlinkage from the teg, its a bolt in simple swap
210racer
03-14-2007 01:38 AM
