need help with my hybrid.....
ok i have a 90 si hatch with a b17 in it......it is running VERY rich and blowing out black smoke.....also is having a hesistating problem....and dosent like to idel right.
that is the problems....i have been told that it could be the fuel injectors but i am using the si fuel injectors not the b17 ones....i also have the pr3 ecu if that helps. i have changed my spark plugs but havent changed the wires yet....can anyone think of any thing that would cause these problems??????please help.. thanks guys
Re: need help with my hybrid..... (lilhibbs)
have you checked the cam timing? maybe the cams/crank aren't set to TDC. That would give you shitty idling problems and odd engine running issues.
Also, is the PR3 ecu stock or reprogrammed?
Re: need help with my hybrid..... (Katman)
hey thanks katman.....yeah i found out i had a hole in one of my vacume lines...then checked the ecu and it was throwing the MAP sensor and knock sensor code.....so i am going to look into replaceing the MAP sensor......the knock sensor was broke when we were putting the motor in...but from what i have been told is that the knock sensor dosent make that big of difference....what do you think....
-but other than that thanks man
well i dont think your MAP sensor is broken physically, or is it? just fix the hose for it and it should be fine.
As for the KS, if you're willing, I can reprogram your ECU (if you have a PR3 ecu) with a Mugen variant which has a few disabled sensors, KS being one of them. Lemme know...
supracrx
10-29-2006 10:00 PM
