O2 Sensors for B16A 1st Gen OBD-0?????
Old 06-06-2002, 08:01 AM
joedr's Avatar
Default O2 Sensors for B16A 1st Gen OBD-0?????
Hi!!
I have a B16A JDM 1st Gen (OBD-0) using two single wire O2 Sensors. I want to know what american spec Honda or Acura car model (model and year) uses the same sensors so I can order them over the internet?
Old 06-06-2002, 09:37 AM
Trey's Avatar
Default Re: O2 Sensors for B16A 1st Gen OBD-0????? (joedr)
You won't find the 2nd O2 here in the states. Primary on is the same as any other 88-91 Honda.
Old 06-06-2002, 01:05 PM
raene's Avatar
Default Re: O2 Sensors for B16A 1st Gen OBD-0????? (Trey)
Is it possible to cut and splice in a different harness, ie. two of the primary style O2 sensors in order to replace the secondary? Or will it not thread into the fitting on the header?
Old 06-06-2002, 02:04 PM
joedr's Avatar
Hi!!
In my engine, both O2 sensors look like the same. Do somebody knows if the 89-91 O2 sensors for US Acura will fit too?
Old 06-07-2002, 12:56 AM
tinkerbell's Avatar
Hi!!
dude, i got the JDM b16a and broke one of my sensors.
i wnet to a wrecker and matched it to the same as teh one as on teh 99 Civic engine...
make sure it has the smae marking on it - mine had NGK on it
PLUS make sure you get TWO of about the same age,
i have one that is 10 yrs older than teh other one and this makes the idle swing a bit as they both try and correct each otehr...
HTH,
t..
Old 06-07-2002, 04:58 AM
jcda6's Avatar
Default Re: O2 Sensors for B16A 1st Gen OBD-0????? (tinkerbell)
Dude, all 92+ Honda/Acura have 4 wire 02 sensors, so I don't see how you got the same 02 sensor as the JDM 1 wire 02 sensor....go ahead and just find any 88-91 Honda/Acura 1 wire 02 sensors.
HTH
-Jeff
Go n 4 10s
03-17-2006 01:44 PM
JOGADOGGZ
09-20-2005 09:38 AM
keebler65
04-16-2003 05:18 PM
handiman15
03-06-2002 07:32 PM
Quick Reply: O2 Sensors for B16A 1st Gen OBD-0?????
